Question about Samsung DLP HL-P5663W 56" TV
Same problem do you know what the part he replaced is? Im hoping to not have a service call as the last one cost me 500 dollars . thanks Tommy
  • demitriusd8 Aug 03, 2008
    my tv was making buzzing sound as the tv was on then it just kept getting worse till it would not come on i would turn it off and on for ten minutes till it came on now it will not come on could that be the lamp that went out thank you
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Call him he might tell you, if he wants to take food off his table.
Posted on Aug 03, 2008
SOURCE:
How much does it cost to fix code p0141 for a buick rendezvous year 2003
The code you are asking about is a o2 sensor Heater Performance Bank 1 sensor 2
In case you're wondering, where the oxygen (O2) sensor that the code P0141 is accusing of being BAD is... it is located on the exhaust pipe after the catalytic converter. The part or the sensor would be around $60 to $79 dollars at your parts store. Hope this helps.
Tommy
Oct 11, 2014 | Vehicle Parts & Accessories
What size battery does Tommy bahama RLX3005 watch require?
1.800.677.8278 All I can find is a phone number. Hope this helps.
Aug 09, 2014 | Tommy Bahama Watches
Where can I buy a replacement charger for my zeki tablet
im done with zeki im better off with an ipad that costs 500 dollars!!
Apr 14, 2013 | Shopnbc Zeki 7" Multi-TouchTablet
How much it's cost please ?
Digital cameras costs above several hundred dollars depending on the brand names and featuree functions. Brand names like sony, philips, panasonic, fuji, samsung digital cameras with features picture video, lenses, storages spaces cost above $500 least considering warantees, and peripheral compartment. Tripod stands, camera batteries, recording chips, carry cases, charger kits, costs differently depenign on the brands names, availability at retain and buyers choice of expensive devices prefered. Recorder camera chips at most affordable with least storage spaces starts at $49 dependign on the type of cameras to suit. camera tripods stands usually would cost depending of the size either as domestic or outdoor setup costs in above couple hundred dollars. $149. Cameras that perform on backup power sources with several hours least requiring recharging are couple hundred dollars and above dependign on the extensive lastings capacity of battery supply at assigments. Consult with an electronic store retailers expert to ascertain the available sale prices. For example, the types of retail stores predict the prices avilable for each device at purchase. for example, products acquired from luxurous retailers requrie guarantee, warrantee acquisition also to make the experince acheievable. Usually more expensive camera devices have more expensive warantee costs at purchase. For example, buying a camera that cost $500 as base price after store taxes of 8% sums much differently. Warrantee may usually become couple hundred, where &149 dollars for basic warantee to several hundred dollars to full extensive years of warantees arragment with either the retails store or manufacturer.
Feb 06, 2011 | DXG Technology DXG-572V Digital Camera
How much does the 60,000 service cost?
The cost can range from 500 to 1000 dollars. It all depends on what has depreciated on the current vehicle. With that said; You should expect to pay around 800 dollars, at most, for the 60k service. You can request to not have certain check points covered to lower the end price, but I don't recommend that at all.
The tries will usually inflate the price past 1000 dollars if they need replacing during the service inspection.
Aug 25, 2010 | 2008 Infiniti FX35
While having freon put into the ac unit dust/smoke flew out. Mechanic says there's a hole in one or both of the a/c tubes and they need to be replaced. Is this a task that requires taking out the entire...
Do not know what he means by tubes,but there is a evaporator core in the dash in the blower box,and if it leaks,it will have this symptom,the cost can be as high as 500 dollars labor,depending on who replaces it.
Jun 15, 2010 | Cars & Trucks
Hi, im doing a project on freezer's and i would like to know how much a freezer ( the one's found in supermarkets, to keep ice cream cold)cost to run per year. thanks for ur help and support.
the best advice i can give you is to pop into a supermarket and ask to look at the freezer motors then work out how many units they use per day,,,or better still ring around the freezer repair shops they are more that willing to help you out if you tell them why you are asking
Nov 05, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Can I replace the battery on my Michele watch anywhere?
It's too expensive to change it on proper service or mall... you can purchase battery for amazon and change it at home, take a look here: Rayovac Batteries Lasts as Long Costs Less. I hope this helped. Cheers
Oct 09, 2009 | Michele Watches
I have a frigidaire model FRT21LRGW, the compressor was changed in 2005, evaporator& heat exchanger was changed in jan.2009. Last week apr.2009 the unit started giving problem AGAIN. Freezer and fridge not...
Possible leak in the sealed system. Make sure the technician pressurizes the system with nitrogen, changes drier, evacuates to 500 microns, then weighs in the correct charge.
Apr 23, 2009 | Frigidaire FRS23KF7AB Side by Side...
Need turbo replaced
You can take it to the dealer and have it replaced for 2,200 to 3,500 dollars.
Or, you can take it to an Independent Volvo Mechanic and spend a lot less!
Lastly, you can rebuild the bad one in your vehicle yourself for 300-500 dollars.
Mar 25, 2009 | 1999 Volvo S80
Samsung DLP HL-P5663W 56" TV Logo
Jerry Greenberg
Jerry Greenberg
Ekse
