Question about Craftsman Garden
My craftsman blower/vac 225 mph, model #136-748270 will not start. Suggestions? Thanks.
Don't do anything with the fuel line or carb. Your model is electric and has neither.
Posted on Jun 22, 2012
5 Suggested Answers
mickey813
  • 472 Answers
SOURCE: need manual for craftsman blower/vac model 358
if you googel searsparts open that link then put in your model number and look for the link that says need a manual for this clik on it and you can get it hope this helps you
Posted on Nov 07, 2009
rotorcrafts
  • 302 Answers
SOURCE: Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
freetek
  • 5568 Answers
SOURCE: craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
Posted on Oct 22, 2010
  • 10 Answers
SOURCE: Craftsman 200 mph model 358.794741 Leaf
You need to check if the piston was fired, or if the piston rings was stick.
Posted on Jan 11, 2011
I'm looking forward to this part of my Craftsman 225 mph blower / vac
Most of the parts that use to be available for that model are no longer available, it is cheaper to buy new one.
Models parts no longer available
136.740360
136.748270
http://www.sears.com/craftsman-2-speed-blower-vac/p-07130376000P?sellerId=SEARS&prdNo=2&blockNo=2&blockType=G2
Nov 01, 2016 | Craftsman Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
Will start and run at half choke. stalls as soon as choke is moved to run.
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Jul 28, 2011 | Craftsman 225 Mph Electric Blower Vac
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
How do I convert from blower to vac
First, remove the blower tube. Then connect the collection bag on the blower tube outelt. Then open the bottom fan cover. Keep it open and connect the vacuum tube into the opening.
Dec 05, 2010 | Craftsman 225 Mph Electric Blower Vac
Have a Craftsman No. 71-79717 200 MPH gasoline blower vac. Do not have operating instructions. Can you help?
This should be your model number:
358797170
On the right side of this link:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Leaf-blower-Parts/Model-358797170/0247/1503120?searchedModel=79717&blt=
Click on "get manuals" then next page "view manual"
This page should be displayed:
http://www.managemylife.com/mmh/owner_manuals/26375/CRAFTSMAN-Blower-Gas-L0520190?brand_name_search=358797170+CRAFTSMAN
Once the manual is downloaded to the screen there is a save file option on the tool bar at the top of the document. (2nd icon from left)
Thanks for choosing FixYa.
Kelly
Nov 15, 2010 | Garden
WONT START REPLACE ENGINE CARBRATOR ADPT DO TO BOLT BROKEN OFF STILL WONT START
Check spark plug. remove the spark plug, clean it and test it. If it still doesn't start, take the spark plug out, and connect it to spark plug wire and try to crank the blower, and see if it makes a spark, if not you may need to replace the spark plug.
Nov 04, 2010 | Craftsman 225 Mph Electric Blower Vac
My leaf blower doesn't start, I put new gas in it & put new sparkplg but doesn't start. Please help me
you list it as an electric vac if it s gas ans you have changed gas and plug if its older you gase lines could be brittle I had to change them on mine to get it to work
Sep 17, 2010 | Craftsman 225 Mph Electric Blower Vac
Garden Logo
109 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
