Question about Samsung LN46A650 46 in. LCD HDTV
After being on for about 30mins my Samsung Series 8 picture pixelates and sound drops out for a second or two, like it has lost the signal and this repeats every couple of mins after that, the TV is only about 10 months old.
  • Samsung Master
  • 610 Answers
Since unit is less than 1 year old, it would be covered under Samsungs warranty. Call 1-800-samsung and they will set you up for repair with an authorized service center. Your problem could be caused by a bad power supply board or a bad main board.
Posted on May 27, 2010
The picture freezes and the sound is lost. Until the picture returns and the sound returns,this happens every couple of seconds.
If you actually have the Zenith model TV (B25A24Z), the trouble is not in your set. This model has only an analog tuner, and what it sounds like you are describing is digital pixellation. This is what happens with a digital-to-analog converter box when it gets a weak signal, with rain fade or heavy snow on a satellite dish antenna, or when a digital cable system has some signal problems. The converter equipment locks the last complete frame (or breaks up into blocks and freezes) and the sound is muted.
You'll need to look for the cause of your trouble in whatever is feeding the TV. If you have a digital converter box for off-the-air broadcasts, make sure you have a good antenna and all the connections are tight. If you have satellite TV service or digital cable service, you might need to contact your service provider for help in troubleshooting and fixing the trouble.
Dec 19, 2010 | Zenith B25A24Z 25" TV
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a samsung series 5 530 lcd. The picture is to big for the screen. I've tried everything in the manuel. help
Also, Check the picture menus for a pixel-to-pixel or 1-to-1 mode. This allows you to watch an HD signal with no overscan.
Jan 10, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung DLP picture problem
Here is the close up picture of the screen.
Dec 22, 2009 | Samsung HLN5065W 50" Rear Projection...
Turn on tv and purple pixels like snow are spread around tv.
First thing replace any swollen capacitors in the power board.
Sep 01, 2009 | Samsung LNT5265FX 52 in. LCD Television
Screen on my Samsung LE32R87BD goes black for a
Contact Samsung . There is a software upgrade for this.
Sep 01, 2009 | Televison & Video
Image gets pixelated and a black screen flashes
yes its a cable box problem, find the channel you are having more problems with,press guide in the cable box remote and you will see how the box where the video is will still have the problem and the guide with channels info its going to be clean,
100% weak signal
hdtvman
Jun 22, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Trouble with Tuner 2
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
May 14, 2008 | Samsung SIRS4120R Receiver
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung LN46A650 46 in. LCD HDTV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
