Question about Panasonic TC-26LX60 26 in. LCD Television
WEAK SOUND - Panasonic TC-26LX60 26 in. LCD Television
    President:
  • 1,099 Answers
Assuming you are not attempting to play it at ear shattering levels, this may be due to an alignment problem in the IF/audio demodulator, a bad audio IC or other circuitry, bad connection, or a defective speaker.
If your TV has an earphone or audio line out jack, try this to see if it is clear. If so, then your problem is in the final audio amp or speaker(s).
If only one channel of a stereo TV is affected, it is almost certainly the audio amp or speaker for that channel. Interchange connection to the two speakers temporarily and see if the problem moves.
If the problem is at all intermittent - try gently whacking the TV - then it is likely a bad connection - either a cold solder joint or a dirty or tired IC socket.
The audio amplifiers in newer TVs are almost always ICs and replacements are usually readily available. If the IC is in a socket, remove the IC, clean the pins and socket contacts and reinstall it. Sometimes, the contacts on old socket lose their springiness and do not provide solid connections. Such a socket will need to be replaced.
If the set uses discrete transistors, it s also possible for one of these to become noisy.
If your TV is fairly old - 10 years or so - this may be an alignment problem requiring tweaking of a coil in the sound IF. See your service manual. It may be possible to have similar problems with newer TVs but this is relatively rare.
There could also be bad electrolytic capacitors, probably in the power supply area. Even though you might think this would result in hum and there is none (even when there is no audio in the program or the sound is turned down) dried up caps can result in distorted sound that may sound like a sort of clipping. An ESR meter is best for testing (with power off!) but carefully jumpering known good caps across suspect ones (again with power off, then turn on the set and check), will eventually find the bad one(s).
Hope this help...
Posted on May 27, 2010
Car makes a ticking sound when i hit the gas
TICKING NOISES ARE HARD TO DIAG WITH OUT HEARING. BUT SOUNDS LIKE POSSIBLE SPARK KNOCK. POOR GAS, BAD SPARK, IE IGNITION TIMING, BAD/WEAK COILS OR BAD/WEAK INJECTORS. HOPE THIS HELPS
Feb 22, 2013 | 2004 Chrysler Sebring
2009 lancer passenger side speakers crackle and are weak
if they are weak and crackling the weak sound might be your balance and fader .............the crackling is because the voice coil is going out another words they are pretty much junk time to replace them
Feb 15, 2013 | 2009 Mitsubishi Lancer DE
Sound is weak how to increase volume
Please check your all the audio and video connections. Also put the placing of AV Enhancer (button on remote control) in the ON position You can increase the volume by increasing the volume of the TV.
Dec 27, 2010 | Panasonic DVD-S27 DVD Player
Weak sound from TV after dvd/vcr hookup
Use the volume control of your converter box to increase the sound level.
Jul 25, 2009 | Samsung DVD-V9800 DVD Player/VCR
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal
Jul 04, 2009 | Yahoo Messenger
Vizio 42 in. hdtv
ur picture tube might have got weak or ur RGB FILTERS MAY BE WEAK OR RGB CONNECTIONS MIGHT BE WEAK or chroma ic is weak.
u should contact a qualified technician immediately
Sep 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic TC-26LX60 26 in. LCD Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
