Question about Microwave Ovens
Have a microwave model NNSA616W, sre 6C37231152 purchased in 2007. Am aware Panasonic has sent memo to distributors to install 20 amp fuse instead of the 18 amp that was in this model when it was purchased. Took the microwave to Nickersons, Russel Ave., St. Catharines and assumed it would be repaired under warranty. After receiving a bill for $56.50 for basically replacing a fuse I rather upset with Nickersons and Panasonic. Nickersons tell me they only repair what they sell. It all boils down to the customer paying for Pansonics mistakes. Any appliances or entaining systems will not be relaced or new purchases will not be Pansonic. I know you are looking after repair problems, but could you please forward this to your complaint department. Thanks, Allan Smith
  • 180 Answers
PANASONIC BELIVES SERVICE IS THE INTEGRAL PART OF ANY BUSNESS. SO YOU CAN INFORM YOUR EXPERIENCE TO THE SERVICE DEPARTMENT OF PANASONIC IN YOUR COUNTRY.
Posted on Apr 07, 2008
SOURCE:
Panasonic microwave keeps blowing fuses jus put in a new fuse but after a few days blowes another fuse
Luzetta
This is a common problem with microwave ovens and is easy to diagnose. Whenever I replace the fuse, I always perform this test. I don't want the unit coming back in a couple of days with the same problem.
Install a known good fuse. It should be a 20 Amp, Slo-Blo, with a ceramic body. Leave the cover off. Place a container with at least 2 cups of water inside the unit. Cook on high for at least 5 minutes. As soon as it finishes, UNPLUG the unit and feel the fuse. If it is extremely hot, the fuse is going to fail in a short period of time. The fusible material inside the fuse is melting from this excessive heat. It only takes a small amount of resistance at the fuse holder contacts to create this amount of heat. Replace the fuse holder rated at least 20 Amps. The higher the better.
Nov 30, 2017 | Panasonic Microwave Ovens
Tip
Panasonic error codes h97 h98
If it is displaying error H97, or h98, this generally means that the invertor(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnetron may also be faulty.
Here is some more information about the part. The microwave may also have a faulty magnetron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
BEWARE... VOLTAGES INSIDE MICROWAVES CAN KILL
Panasonic part number: Z606YM300BP, supersedes all previous versions of the inverter used with the 2M261-M32J This Inverter is now available at a lower cost, it used to be £60.00 plus VAT and delivery trade price.
This inverter is fitted to many of the more recent Panasonic inverter type microwaves such as the NNC596S .Some microwaves such as Bosch and Siemens also use this inverter as they are rebranded Panasonic ovens. These ovens are upmarket models, some include advanced functions such as steaming and are normally well worth repairing.
The inverter as fitted to earlier ovens with the 2M236-M42 and 2M236-M1 is also available.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
As well as the inverter failing it is also possible you could also have a defective magnetron,
Good luck and thanks for using FixYa
A FixYa rating would be spot on for this information to you.
ask
robotek
on May 07, 2008 | Panasonic NN-SN657S Microwave Oven
Panasonic Microwave Oven unexplainedly without power. Model No. NNS954WF. Serial # 6A34160395.
If you remove the microwave case, follow the power cord inside the microwave to the fuse. Panasonics will usually have a 15 or 20 amp ceramic fuse available online or at a local appliance repair shop. Of course remove power from the MW and don't touch any wiring or terminals except the fuse wiring.
Nov 14, 2017 | Microwave Ovens
Microwave starts then quits, turntable doen't turn
At this time we recommend you locate an authorized service center using the below link. www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 03, 2014 | Panasonic Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Panasonic Microwave has no power
There is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. Searspartsdirect.com has some excellent exploded view parts illstrations you can use to assist you in component location and assembly.
If the model number is correct, the fuse is listed as item 55 in this parts illustration:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f50029794-00001.png
There are also a couple of thermal cut-outs listed as items 51 and 52. These can affect the operation of the oven as well, but usually are related to overheating something in the oven cavity. If you haven't overheated the oven cavity recently, its probably the line fuse. (Popcorn and Potatoes are notorious for causing overheat problems).
You can purchase repacement fuses for appliances at any hardware store. Just make sure the rating is the same as manufacturer installed fuse. You need to purchase a 125V, 20AMP, slow blow for best results.
To answer your question about the fuse blowing when the unit is not in use...Yes, this does occur. You may have experienced a minor power fluctuation such as a brown out over the night that could have caused the fuse to blow. Some components are more sensistive to variations in current than others.
Another possibility that I have to mention is roaches. This does not in any way insinuate you live in filthy conditons, or have an infestation. I just need to mention that insects (such as roaches) are attracted to electronics. Especially, where there may be food. Since their body composition is mostly made up of water, if they crawl across an electrical component, they could cause a short circuit and blow a fuse.
Apr 18, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Microwave Ovens Logo
470 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
