Question about Danby DAC8003D Air Conditioner
Installation air conditionning in a window
Where could i find the installation manual on the internet to install a
air conditioning 8000 btu window mounted
  • 28 Answers
If this is the Danby 8003 you mentioned, here's a link to the unit's manual. That should get you what you need. Good Luck!
http://www.retrevo.com/support/Danby-DAC8003D-Air-Conditioners-manual/id/886bh629/t/2/
Posted on May 27, 2010
    Habit-Forming:
    New Friend:
  • 6 Answers
I'd rather hire a professional company to perform that service. We have a window air conditioner that was perfectly installed by Classic Air Conditioning Air Conditioning Repair and Service Boerne TX Classic Air Conditioning... they did an amazing job in a place that I thought to be difficult to have an air co in. Thanks them now we have cool summers again.
Posted on Dec 04, 2017
Tip
Central Air Conditioning or Window Air Conditioner
Many people look into installing air conditioning in their home every year. There are many options to consider when it comes time to make that decision. To help make that decision more clear, I will explore some of the positives and negatives of the two major options. Ductless Split A/C type units lately are also becoming more of a popular option. I will do another “Tips and Tricks” on that option. To include that in this one would just be more confusing. So for now we will just look at window air conditioners and central air conditioning.
Central air conditioning is usually the best way to go if you already have a central hot air heating system already installed in your house or building. The advantage that you have is that you already have the air handler or blower part already installed. The ductwork for the distribution of the air is also all ready in place. The ductwork may need some modification to make it work well for air conditioning, but the major part of it should be adequate. To use the existing furnace and ductwork an A/C coil will need to be installed at the furnace. An outdoor condenser unit will be installed outside and copper tubing will be used to connect the coil to the outdoor unit. Some electrical wiring will need to be done to power the outdoor unit. Low voltage wiring will also be needed to hookup the thermostat, the furnace, and the outdoor unit together so that they can talk to each other. Basically the thermostat will just tell the furnace to run the blower on high speed and the outdoor condenser to start up.
If there is no central hot air heating, then the installation of central air conditioning can be much more difficult. Many homes that do not have hot air heat also do not have the room to install ductwork. This would eliminate this possibility. If you are in this category you should get a professional to look at your situation to see if central air conditioning can be done. If it is the room available is to enough to do a good job and get large enough ductwork installed, then do not force the issue and go another option. Ductless split type air conditioning may be your best option.
A window air conditioner in my opinion is a last resort for air conditioning your house or building. There are many down sides to window air conditioning units. There are two good things that window air conditioners have going for them. They are very inexpensive when it comes to cost per BTU of cooling. They also install very quickly and easily. That is where the good part of them ends.
Window air conditioners are security risks. If a thief wants to get into your house, the thin sheet metal box that holds the unit in the window can easily be pulled apart to get in through the window. I have seen many units that are not even screwed fast. If the window air conditioner is just there, balancing in the window frame, it becomes very inviting for a unexpected guest. The window air conditioner is also very inefficient. These units use more power per BTU of cooling than any other type of air conditioner. If you are a light sleeper, than chances are you will not want one of these window shakers. Window air conditioners are one of the loudest forms of air conditioning.
The fan for these units is very loud when running. Then add the noise of the compressor and you have enough decibels to keep many people wide awake all night long. If you choose to use a window air conditioner, than you should also look for a place that it can be secured and placed in a room that you will not be sleeping in.
As you can tell by now, I am not a big fan of window air conditioners. They do have a place for some people. However, you do need to be aware of the problems that you may encounter with them. The low initial cost can be offset by the fact that they typically do not last as long as a central air conditioner.
Central air conditioning will last much longer, be quieter during operation, be more efficient, be more secure, but the initial cost will be higher. How much depends on each situation. When considering your options for air conditioning installation you need to get prices for everything and then decide what type of unit will work the best for you.
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
http://www.fixya.com/support/r3636751-air_conditioner_seer_seasonal_energy
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
on Jan 01, 2010 | Heating & Cooling
Is there any kinds of problems with this air conditioner
Here are some reviews and questions that have already been asked on Fixya. any appliance that is only used for a few months of the year and then rests for months is going to exhibit some problems eventually. Usually just a matter of getting an AC engineer to add some more refrigerant gas.
  • Amazon.com: Customer Reviews: Arctic King MWK-06CRN1 ... www.amazon.com/Arctic-King-MWK-06CRN1-BJ7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-06CRN1-BJ7 6,000 BTU Window Mounted Air Condit at ... COOL AIR coming out of the Artic King.
  • Amazon.com: Customer Reviews: Arctic King MWK-05CMN1 ... www.amazon.com/Arctic-King-MWK-05CMN1-BI7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-05CMN1-BI7 5,000 BTU Window Mounted Air Condit at Amazon.com. Read honest ... by Arctic King...
  • Review of my Arctic King 5,000 BTU Air Conditioner - YouTube www.youtube.com/watch?v=oaB2CPeZLTs
    • BY GOLDENSONIC08
    • 7 MIN
    • 20K VIEWS
    2014-06-09 · Video embedded · Just a quick review of my Arctic King WWK-05CRN1-BI7 5,000 BTU air conditioner.
  • Arctic King 10,000 BTU Energy Star Window Mount Air ... https://jet.com/product/Artic-King-10000-BTU-HomeOffice-Window... This Arctic King Air Conditioner is designed to be installed in a standard double ... This 10,000 BTU window mount Arctic King Air Conditioner is one of the most ...
  • How to Repair Window AC ' eBay www.ebay.com > ... > Heating, Cooling & Air > Air Conditioners A window-mounted air conditioning unit can be a lifesaver for anyone in ... How to Repair Window AC. ... Arctic King 8,000 BTU Energy Star Window Room Air Conditioner ...
  • ACE Artic King Window Mount Air Conditioner 5,000 BTU ... www.fixya.com > Forum > Air Conditioners > ACE Recent ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK-05CMN1-B, 1 ea questions, problems & answers. Free expert DIY tips, support, ...
  • ACE Air Conditioner Problem Support, Troubleshooting Help ... www.fixya.com > Forum > Air Conditioners ... Manuals & Customer Service for ACE Air Conditioners. ... ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK ... ACE Artic King Window Mount Air...
  • Jun 09, 2016 | ACE Artic King Window Mount Air...
    Water is leaking in front
    Tip the air condition back so water drains outside window.
    Jul 14, 2013 | Haier Esa408k-l Window Air Conditioner...
    I bought Air condition today(Haier 8000 BTU) I install my living room but it doesn't cool it,the setting is Cooling and high,please help me before I return it.
    I would take it abck. Iknow its not the answer you want to hear but it might save you a lot of heart ache in the future
    Jul 19, 2011 | Haier Heating & Cooling
    My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
    The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
    A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
    So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
    If it's not well insulated you will need 24,000 btu.
    Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
    8000 btu window unit freezes up on all settings. I have completely cleaned out the unit and it is at a slight angle to allow the water to drip from the bottom outside. I am wondering if this is a problem...
    It may be the environmental conditions such as a lot of humidity and the way air moves through the area, if the coil frosts completely it's lack of load/airflow per load, if the coild frosts up partially its from operating in low ambient or lack of refrigerant.
    Jul 23, 2010 | Whirlpool Electronic Window Air...
    Window unit air conditioner leaking water inside home
    well it might not be tipped at a angle so the water comes to the front tip it back some
    Jul 10, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
    Danby DAC8003D Air Conditioner Logo
    386 people viewed this question
    Top Danby Heating & Cooling Experts
    coolfelix
    Level 1 Expert
    Dan Webster
    Dan Webster
    Dennis Boxerman
    Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
