Question about HP J3680 Officejet All In One Printer
Unable to send & Receive fax from hp officejet j3608
4 Suggested Answers
  • 108 Answers
SOURCE: HP Officejet v40 - Can send faxes but can't receive
I think you like to setup it for auto FAX. In any case go to setting menu and set as auto and then set after 5 or 6 rings (or as you wish). You can also do the same if you have the utility software that come along with this Officejet model.
Posted on Feb 08, 2008
SOURCE: unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Posted on Dec 23, 2008
  • 80 Answers
SOURCE: HP officejet J3608 says "
hello there,
Kindly check this lin out and there is a scan diagnostic tool you can download.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02575922&cc=us&lc=en&dlc=en&product=3441011&tmp_track_link=ot_search#N41
This document will provide you a step by step solution to fix your issue.
The good thing about this is that it also provides full illustrations
Leave a feedback and testimony if it works.
Posted on Mar 12, 2011
I am unable to send a fax or receive, how do i correct problem
Uninstall HP Photosmart software and Drivers for printers. Remove all the HP softwares. If you have CD reinstall printer and HP Photosmart software from the CD.
Other wise download the complete software and drivers from following link.
http://h10025.www1.hp.com/ewfrf/wc/product?product=1119598&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 06, 2011 | HP Officejet 6310 All-In-One InkJet...
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
hello there,
Mar 12, 2011 | HP J3680 Officejet All In One Printer
How get faxed confirmation HP officejet 6500
You can enable fax confirmation before sending a fax by selecting Send & Receive
Press SETUP on the control panel
Press PRINT REPORT, then FAX CONFIRMATION
Press right arrow to select SEND & RECEIVE
Press OK
Additional instructions from HP Support User Guide
Click on link and select FAX
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Feb 19, 2011 | HP Officejet 6500 Wireless All-in-One...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Our hp officejet j3608 has problem receiving and sending faxes..what should i do..the manual doesn't give any instructions how to use the fax..please help me..
revise la linea telefonica por si tiene da?adas las terminales aga pruevas aciendo copias si las hase bien aga llamadas y si no revise la comfiguracion desde el menu en el teclado usando las teclas de menu,set, botones de direcion
Oct 05, 2010 | HP Office Equipment & Supplies
Epson workforce 610 cannot receive faxes
check your rx setting (receive) mode ?, fix it to auto mode
Jan 28, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
HP J3680 Officejet All In One Printer Logo
287 people viewed this question
Seeker5211
Seeker5211
