Question about Fuji FinePix S1000FD Digital Camera
FinePix S1000FD: FOCUS ERROR
Hello!
without warning my FinePix S1000FD has shown the error message "FOCUS ERROR" and it is not more possible to do photos. It is impossible to close the objective too.
It is only one year old.
Please, is there some solution in order to fix the problem without to send my FinePix S1000sd at Fujifilm Assistence?
Thanks a lot for your help!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
Testimonial: "Hello typrice! I have tryed the following steps: Fix #1: tryed without result by batteries rechargeable NiMH 2600mAh; Fix #2: tryed without result; Fix #3: tryed without result; Fix #4: tryed without result; Fix #5: tryed without result by compressed air; Fix #6: GOAL! I have tapped delicately the bottom and the left/right sides of my Finepix S1000sd on an armrest and in the same moment I have turned on/off more times. Now, my Finepix S1000sd is working! Thanks a lot typrice for your useful help! "
Have a fujifilm finepix s1000fd and when I use
Your cameras focus lens is probably stuck.
It operates via a long metal rod, a pin which follows a track in the side wall of the lens and a tensioned spring. one or more of these has probably jammed causing the focus lens not to move when you zoom.
Unfortunately for this camera, if you cannot free it by switching on/off, tapping the lens etc, you will have to strip the camera down to get at the lens unit. you will have to discharge the flash capacitor before desoldering the control board from the main board before removing to access the lens.
Recommend you find someone who knows about this or send to Fuji.
Apr 05, 2010 | Fuji FinePix S1000FD Digital Camera
I get a 'focus error' message from my fujifilm s1000fd camera. What can I do to fix it? I would like to fix it w/o spending money...
My email address is on my tips page on my profile under" THE ONLY WAY I KNOW HOW PART2.."
I can talk you through it but it isn't easy
Jan 24, 2010 | Fuji FinePix S1000FD Digital Camera
Focus error - can not get rid of . I have taken out the batteries and still comes on screen.
The focus mechanism for this camera is different from other Fuji cameras in that instead of using 3 evenly spaced guide pins like on smaller compacts or, a motor and drive thread like the S5600 or S5700. The S1000fd uses a guide rod and spring and 1 guide pin to move the focus lens up and down to sharpen the picture. 1 pin is all that can jam and cause problems. Getting to it involves desoldering the control board from the main board just to access the lens unit. Then desolder 2 ribbon strips and secure 2 tension springs before you can remove the lens construction.
Dec 01, 2009 | Fuji FinePix S1000FD Digital Camera
My FINEPIX s1000fd fujifilm camera says that it has a Focus Error and lens will not retract,i have tryed reseting it twice! please help meeeeee.
You will need to take this to a technician as this is very delicate. They have a tool that will fix this problem. I wouldn't recommend trying to fix this yourself because when you open the lens, it has many parts and springs.
Oct 28, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom error
If you are in a mode such as macro of some other modes then the camera is unable to focus when the telephoto lense is extended past a certan point, mine has never told me in that way, but I am sure that that is the problem, just zoom out to the widest angle possible then in photoshop you can crop the image later.
Jul 21, 2009 | Fuji FinePix S1000FD Digital Camera
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen Focus Error and lens will...
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Apr 02, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
Fugi s1000fd
I CAN'T INSTLALL THE SOFT WARE PROPERLY, I AM GETTING A ERROR MESSAGE LIKE "I/O ERROR OCCURED".
Feb 25, 2009 | Fuji FinePix S1000FD Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
448 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
