Question about The PHP Group PHP
How to set listen_addresses (string) of TCP/IP as
How to set ''listen_addresses'' of TCP/IP as (*) for postgre server start in window XP
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
How do I hook up your router to make my laptop be wireless........it has to go through a contrend router that is on my desktop computer
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G wireless router does not connect to our laptops. The (4) wired ports work fine. What am I doing wrong?
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
How do I install Konica Minolta Bizhub C350 copier using a router and 1 computer with Vista 32-bit?
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Oct 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Well you please tell me default IP address of LINKSYS Wireless-G Print Server
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
Jan 22, 2009 | Linksys Wireless-G WPS54GU2 Print Server
Useing Linksys wpsm54g with tcp/ip
that will depend on the IP address of the print-server and the network, specially if the printerver is not set to a static IP, you may get communication errors when you try to use or install the printserver.
you may try to set the PS to have a static IP address or you may use the printserver name instead of its IP address.
use custom settings then use "RAW" after that chnage the queue name to p1 or l1.
there are many work arounds for this kind of limited configuration, but i would strongly suggest you call Linksys Toll Free Tech support for more configuration
Sep 30, 2008 | Linksys WPSM54G Print Server
D-LINK DP301U
TCP/IP printing for windows xp:
you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
Step 2 Select Local Printer and click Next.
Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
Step 5 Enter the IP address of the print server and the port name and click Next.
Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
Step 7 Click Finish to close the port configuration wizard.
Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
May 29, 2008 | D-Link DP 301U (DP-301U) Print Server
The PHP Group PHP Logo
156 people viewed this question
Top The PHP Group Computers & Internet Experts
dhnguyen
Computer Links
Mike
Are you a The PHP Group Computer and Internet Expert? Answer questions, earn points and help others
