Question about Quintum Tenor AXT2400 (501014800) VoIP Terminal Server
We have Quintom tenor AX, this is the information of my device System Software:P105-19-14 SIP Module:2.1.0 Boot Software:P106-02-00 Database Version:DB_CMS_M11_A015_V9.1.00_092506 with 24 ports as FXO and FXS This is our Requirement 1 ? Call Routing dial out or dial in with specific port in Quintum Tenor AX gateway Scenario: 1. Tenor AX is the FXO gateway in our system. 2. Our PBX is based on asterisk and it is connected to quintom as a VOIP account. 3. Creating more SIP user agent in quintom allows us to have more VOIP account in our asterisk PBX, therefore allow us to have different call routing options. Example : Ex. Extension 100 can access (00) telephone line which is connected to port 5 in the FXO switch, extension 200 can only access (0) telephone line connected to port 6. We are facing these problems in Quintum Gateway : 1 - we can make only single concurrent outgoing call using PSTN ( if we make second call system generate message all circuit are busy and we have 4 lines connected to Quintum ) 2 - Called party is busy or his mobile is switch off, Quintum gateway cannot detect signal please help very urgent
  • 560 Answers
Hi. Open the "Outbound Routes" on your Asterisk box and edit the route you want to have multiple PSTN lines available, scroll down to "Trunk Sequence" and add several "ZAP/X" by clicking the arrow down and selecting the correct trunk. Replace "X" by actual trunk number.
Posted on May 28, 2010
  • bits2009 May 29, 2010
    (Asterisk ---- Quintom ------ PSTN lines)
    we could connect quntom to asterisk, but the problem is:
    1. Call Routing dial out or dial in with specific port in Quintum Tenor.
    EX. Extension 100 can access (00) telephone line which is connected to port 5 in the FXO switch, extension 200 can only access (0) telephone line connected to port
    2. we can make only single concurrent outgoing call using PSTN ( if we make second call system generate message all circuit are busy eventhough we have 4 lines connected to Quintum )
    3. If Called party is busy or his mobile is switch off, Quintum gateway cannot detect signal
Toshiba e-studio 356SE error code f 121 Database abnormality user information management database
user management database is corrupted.
Delete the log in the following procedure:[5] + [C] +
[POWER] ? 4. Initialize database ? 1. LDAP database
(to delete user database) (Note that all user, role, group
and accounting data will be deleted.)
If the error is not recovered, reinstall the system software.
([4] + [9] + [POWER] -> 4. System Software(HD data))
Jul 14, 2016 | Toshiba E-Studio 356 Multifunction Copier
I want to confugre Tenor A800 to make SIP
Hi
For making/reciving SIP calls with A800 u need its SIP firmware.
u can add me on MSN for more help.
MSN : hezare3@hotmail.com
Apr 22, 2011 | Quintum Tenor A800 (501-0026-00)
Hello sir i lost my tenor ax series gateway license file by doing reformat flash now i need license file how i can get?
http://www.quintum.com/
go to the link above and then go to the support tab then look for chat or telephone number and get a rep they can give you a new or temp license tell them it got lost and they will replace.
Jan 23, 2011 | Quintum Tenor AXT2400 (501014800) VoIP...
Hi how to resolve quintum ax series problems license hardware configuration mismatch is the problem
You need to request a new/updated License file from custspt@net.com
plz note that the quintum.com is net.com now.
Aug 23, 2010 | Quintum Tenor AXT2400 (501014800) VoIP...
Trust HD Widescreen webcam. pc - Windows
Try re-installing the webcam software & use updated files if the maker offers them. You can also right click the short cut icon & make sure that run as administrator is checked & also run in compatibility for xpsp2 is checked & try it again. Those numbers are great but unfortunately, not even microsoft knows what they mean,lol. Believe me I've tried thier support a few times with "codes" & they told me they're just generic & don't point to anything usefull.
May 11, 2010 | Computers & Internet
I have a tenor dx 6120 connects to an omnipcx office but i cannot make a voip call with it although I 've configured it to make sip call
Unfortunately, there are any number of reasons this could be a problem. The only sure way to tell what's going on is to look at the SIP traffic directly.
If you are up for it, here are the steps you'll have to take:
1. Download and install Wireshark(it's free) from www.wireshark.org
2. Install wireshark on a PC and connect it to the same switch as the Tenor,
3. Configure the switch to use the PC port as a monitor port for the port the tenor is connected to; you need a managed switch for this.
4. Start a capture with Wireshark for the appropriate interface. You'll probably see a shocking amount of traffic on your network all of a sudden. Don't worry, we're going to filter out the stuff that doesn't matter and it will be much more manageable.
5. Click the Telephony tab and select "VOIP calls". Try to make a call or two and see if this provides any useful info.
6. If #5 didn't help, go back to Telephony and select the "SIP" filter. This will provide more basic info on what is going on with the Tenor by showing every SIP packet. If you don't know anything about SIP it can be pretty hard to read though - you may need to post results here and let us take a look.
Jul 15, 2009 | Quintum Tenor DX2048 (501012100) 2x10/100...
Machine hangs and freezes.
check for viruses in the system, try to update virus database defintions engine, the keep full system scan hope it will works.
Mar 23, 2009 | Quintum Tenor DX6120 (501011900) 8x10/100...
WINDOWS EXPLORER HAS STOP WORKING
Hey there
The problem could be because earlier version of nero You can solve your problem from doing the following:
If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
If you’ve upgraded Nero and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
This will break Nero Showtime, however.
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate or windows explorer) can fix this problem. This solution is detailed below.
Right click on Computer, and choose Properties
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe
Click Open, and then OK.
Enjoy working
Gimme your acknowledge by rating me
thanx
Romy
Oct 18, 2008 | Computers & Internet
Quintum DX2060
http://www.quintum.com/support/products/2G/tenor_2G/sysdoc/webhelp/calleridgeneration.htm
Try the search box at this URL: http://www.quintum.com/support/
Just copy & paste the parameter name into the box.
Jan 13, 2007 | Quintum Tenor DX2060 (501-0122-00)...
Computers & Internet Logo
393 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
