Question about Microsoft Windows® XP Professional Full Version OEM for PC
Sir, when I start the computer it is not getting booted. Some time it works and some time it says no operating system found. It goes up to message F1 for set up and F2 to continue. Can you help me. regards. Window XP iam using
    Problem Solver:
  • 12 Answers
This happens when your computer can not find/read the drive the operating system is installed on.
If you have more than one hard drive and/or optical drives installed your BIOS is probably selecting the wrong one to boot from. Select F1 and go tothe boot menue and ensure you are booting from the drive you desire first, it can boot from several drives but in the order you choose.
Loose/dirty drive connectors are often the cause of this problem, clean/replug them.
A slightly faulty hard drive can also cause this intermittant problem. Go to the Start menu, then Accessories and then Command prompt. Once in DOS type in CHKDSK/F. CHKDSK will report problems but not fix them without the /F after.
All hard drives develope dad sectors which are usually corrected without you knowing about it, fixing it with the above does not neccassarialy mean your drive is bad and needs replacing. I have had to run CHKDSK/F many times in order to repair a small failing section of a drive that has then lasted many nyears
Posted on May 27, 2010
I have dell optiplex 330 when i start it it need to strike f1 for boot f2 for setup and f5 for scanning
There could be two reasons you are getting this error message .
1. The operating system has crashed and needs to be reinstalled
2. The HDD has gone bad.
Run the diagostics on the computer.
Restart your computer at the Dell logo , tap on the f12 key slowly 1-3 times.
Using your down arrow key on the keyboard highlight IDE drive diagnostics or HDD diagnostics.
Press enter .
Incase there is an error , the hard drive needs to be replaced , else the operating the system needs to be repaired or reinstalled .
Thanks for using fixya
Proton
Jul 05, 2012 | Computers & Internet
This problem just started yesterday.When booting up,the first screen with the white bar goes across,then it goes to a black screen and beeps once with the message,hit F1 to reboot or F2 to setup menu,but...
restart your computer press F8 then click restore the directory setting this will restore all the directory in the system and the system will reload properly if this doesn't work you will have to re install the OS
Jun 28, 2011 | Dell OptiPlex GX110 PC Desktop
Hello, I have a problem with my computer, I think all started with a virus when downloading a program to diagnose the pc or a driver for the modem, try removing the virus with several antivirus with no...
I think you just erased your hardrive. (Or it wouldn't show the Operating system not found message).
That means your data is already lost. (Unless you have 2 harddrives in your pc)
Get a Windows Installer CD from a trusted source. ( Maybe the local computer store can lend you one)
Test this cd on another pc (By just booting the cd , not by running the installer!)
Install Windows using this cd (Start it using F12 like you said)
May 15, 2011 | IBM Computers & Internet
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
The disc drive will no longer pop open
This happens from time to time. Could be time for a new disk drive. In the mean time,
Shut down the computer for about five seconds and then turn it back on. Start pressing the key that gets your computer into its BIOS settings.
***To enter the BIOS, press the Esc key when the Toshiba script shows up on the display. You should then get a message to press the F1 key to continue. Press the F1 key and you should be in the BIOS. The Boot sequence is on Page 2 of the Bios settings on many Toshibas. To get to page 2 press the page down key. Make sure you follow the screen prompts because your system may be slightly different.***
That key is different on many brands of computers. It may be displayed which key it is on your screen on boot time; but, that message comes and goes quickly.Once in the BIOS, do not make any changes to settings. Simply attempt to open your CD drive. If it will not open while the BIOS screen is open, you have a hardware problem. If it does open, you have an Operating System problem.
That being said - you can open the disk drive manually by inserting a paper clip or push pin into the hole in the front ot the drive. (see picture below)
Jul 03, 2008 | Toshiba Computers & Internet
Cd drive changing
Your computer cannot find The Hard-drive Or operating System.
Your Primary Hard Drive, is reporting an error.
Try changing the Jumper setting on this From Master To slave.
( jumper is amall plastic Block ) on back of drive.
Then set your CD/DVD To Master.
Mike @ Compurepair.
Mar 14, 2008 | Audio Players & Recorders
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
When booting system I get message: Hardware Monitor found an error. Enter power setup
this is a sign that your cmos battery needs replacing on the motherboard its a cr2032 flat disc shaped battery and normally resides near the memory slots. The battery being flat is losing all the hardware and bios settings, F1 just passes this check and allows a boot, you will probably find the time and date is incorrect which is a sure sign of battery problems
May 27, 2007 | Sony VAIO PCV-RX753 PC Desktop
Microsoft Windows® XP Professional Full Version OEM for PC   Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
