I have a Minolta EP-2050 copier that needs part #1136-6804-02 wire harness. This is the cable that goes to the exposure lamp. This part is no longer available. Any suggestions as to where to get obsolete parts? Howard T.
  • herbhoward Apr 10, 2008
    I have tried the e-bay thing and no luck yet.
    I have talked to ARC Services and no luck. I also talked to Percission Roller. Minolta charges only $27 for this cable if they had it. Hard to give up for such a simple repair. It's hard for me to give up.
    Herb
  • 871 Answers
Hey herb
maybe theres is another name for that type of harness.. have you tried checking out this site here
if its really that hard to find, why not look for a same copier thats in auction on ebay or such... then you can just get the wire harness...just a thought.
Posted on Apr 10, 2008
  • earl norman llanera
    earl norman llanera Apr 10, 2008
    herb,
    suggestion, if you still have the old wire harness... you could look for a particular specialty shop which would make an exact replica for that. it may be a long shot but so far, since this harness is low stock or no stock at all, this may be your only chance.
    27 dollars aint so bad...it would definitely give more than that it exchange for the services right...
  • 2,335 Answers
It looks like the manufacturers do not keep a stock of parts for servicing.
Is this like a flex ribbon cable?
You can try to customize it, since I do't think you would be able to find a part like that unless you buy another non working device similar to yours.
  • Jaime Hernandez Apr 10, 2008
    Try to call this site and ask them if they could help you.
  • 3,037 Answers
If anyone would have it, I think this company would, give them a call. I tried but they were closed. I found their hours now too.
Order by phone: (800) 323-9523 - Hours: M-F 7AM to 5PM MST
Let me know how this turns out. thanks
  • Benjamin Patri
    Benjamin Patri Apr 10, 2008
    If I were you, knowing that they don't make the part makes it feel like the right time to just upgrade to a newer model. Please let me know if you need any further help. Thanks and Have a Good Day.
  • Benjamin Patri
    definitely a hard part to find, been looking the last hour, Is there anyway that you could possibly wire it up or maybe use a wire harness from a different model, I would call the company and see if they know of any compatible ones or even email pictures of the piece to other manufacturers and see if they have one that might work.
    Master:
  • 555 Answers
Precision Roller. They have tons of old parts.
  • Matt Jurach
    Matt Jurach Apr 10, 2008
    And if they don't have a part, they'll track it down for you.
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
Please i want clean the copies machine minolta cs pro ep 4000
Dear
the best clean is to take the glass out and clean all the mirrror you can see in the exposure system also you must clean the exposure lamp with the alcohol
that all you can do alse if the the copies still dirty that mean there are another problems in your copier must check.
Nov 25, 2011 | Minolta Office Equipment & Supplies
My minolta cps 500o prints all black pages...what is the problem?
Hi check that the exposure lamp is coming on place a sheet on the glass press start and see if the exposure lamp comes on and stays on as it copies if it does not come on then you need to check the lamp and the scanner cable for the lamp
if this dose not resolve your issue check the main charge on the drum check the corona wires are intact
The above will resolve your issue
Feb 10, 2011 | Minolta EP4000/5000 CS/PRO Copier
Ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Jul 16, 2009 | Minolta EP1030/1030F CS/PRO Copier
Code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Feb 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
Minolta EP2030 exposure lamp timing wrong
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Nov 13, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
Nov 04, 2008 | Office Equipment & Supplies
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
what is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Oct 05, 2008 | Minolta Office Equipment & Supplies
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
k24674
jasbo
jasbo
