Question about Toymax Binatone Carrera X350 Car GPS Receiver
Update my x350 2nd edition satnav(binatne carrera)
3 Suggested Answers
SOURCE: binatone carrera x350
I have accidentaly damaged the screen of my binatone carrera x350,rest the navigator is in working condition , the problem is that the touch screen has been scattered .can i get it repaired
Posted on Jul 13, 2008
SOURCE: Hi my name is jamie
hi jamie firstly you will need to connect your receiver to the pc go to the binatone website and look for updates you may have to pay for them goodluck
Posted on Mar 30, 2011
I need to update my Binatone carrera
here
http://www.binatone.com.au/gps/support.php
Binatone
May 14, 2015 | Toymax Binatone X430 GPS Receiver
Tip
How to update your Garmin Satnav maps
To update your garmin satnav map you must have your satnav registered. If it's already registered skip to paragraph 2 below.
1. To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on Register your garmin product
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
2. To update your maps
  • Connect your satnav to your computer and go to www.garmin.com
  • Click on myGarmin and log in
  • Click on myMaps.
  • If there's an update available it will be shown beside the name of your map.
  • Click on Get Update and follow the prompts.
Note map files are large so you'll need a broadband connection to download them. If you don't have broadband you'll have an option to buy the update on DVD.
  1. If The Map Is Too Large To Install To Your Satnav
    When you go to download the map by default it tries to download it to the satnav i.e. not the SD/Mini SD card. You need to change this. When the website recognises the satnav follow the prompts. It will give you 3 options for the download destination.
    • Download to satnav,
    • Download to Computer and Satnav or
    • Download to computer.
    As the website is updated, from time to time, the method of selecting the download destination changes. Sometimes it shows up as a drop box with a drop-down arrow showing your satnav name. Click the drop-down arrow and select the option to download the map to your computer. Sometimes it shows the 3 options as text headings with tick boxes beside them and you get to tick the option you want. Whichever way it shows up select the option to download the map to your computer. This will install it on your computer's hard drive.
  2. After it's downloaded the map should begin to install automatically. (If not double click on it and it will). It should be allowed to install to your satnav first as Garmin will not allow it to install to your SD/Mini SD card unless it's first partly installed to the satnav. This is so they can ensure that it's installed to the correct satnav.
  3. To Install The Full Map To Your SD/Mini SD Card
    To install the map to your SD/Mini SD card, insert the card into the card slot of your satnav and connect it to the computer. Click the windows start button on your computer. Then click the GARMIN progam and then MAPINSTALL. This runs the map installation program. When the install program finds your satnav and you get the option to install the map there again by default. Click on the drop-down arrow, where it shows your satnav as the destination, and select the drive letter of the SD/Mini SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD/Mini SD card.
  4. Problems With Older Nuvi Satnavs Reading Maps On 4 Gb Or Higher SD Cards
    When you install a map to an SD card older nuvi satnavs can have difficulty getting the satnav to read it. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down the satnav unless you remove the SD card. The reason for this is that 4 Gb and higher cards are SDHC which operate differently from SD. To solve this problem you should use a class 2 SDHC card, which is the slowest type available. You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10. Before you install the map format the card as described below. Also use webinstaller to check that you have the latest version of operating software on your satnav.
  5. Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive or indeed your satnav just as easily if you select one of them by mistake.
  6. To update your software or check that you have the latest version, you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
    Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are harder to find in shops today as they are being replaced by the faster classes. They are however still easily available on ebay if you can't find one in the shops.
on Aug 17, 2010 | GPS
Whts the difference bet lt and lmt
Satnavs with LT on the name have free lifetime traffic updates included with the satnav.
Satnavs with LMT on the name have free lifetime maps and traffic updates.
NOTE: Lifetime means the life of the satnav not your life
Jul 12, 2011 | Garmin GPS
Hi my name is jamie ive just bought a binatone carrera x350 satnav &i need to get it updated the software version in it now is Ver 1.0.1 can you tell me how i can get it updated please
Mar 30, 2011 | Toymax Binatone Carrera X350 Car GPS...
Need cable to update garmin nuvi only plug besides adpter is looks like sd card opening?
The cable you use to update a garmin satnav is a mini USB cable. This cable has a USB plug on one end and a small dovetail shaped plug on the other end. Most garmin satnav models have a plug in the back of the satnav, the same socket that you use to charge it. Some models have a socket in the bottom of the satnav beside where the power goes into those models. To update the satnav plug the small plug of the mini USB cable into the satnav socket and the other end into the USB socket of your computer.
Full details of how to update your garmin satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Feb 21, 2011 | Garmin GPS
Need free map updates on binatone sat nav a350 how to install
my dad bought this a few years ago and never used it and he only found it when recently moving house he cant get any maps on his binatone satnav a350 when we press navigation it doesnt do anything it stays on the screen. im picking up 8 gps signals please help
Sep 23, 2010 | Toymax Binatone Carrera X350 Car GPS...
Gives me wrong instructions
Unfortunately there's no solution to this problem. Software selects what it thinks is the best route but very often this is far from the best route. Different makes of satnav use different software. In tests he best has been shown to be the Garmin satnavs. Even these are not foolproof but they are close.
Jul 27, 2010 | Toymax Binatone Carrera X350 Car GPS...
Nonecontinuous street on satnav but continues
report the error to TomTom via their website. Their provider will then update the map but you're stuck until you update your map
Oct 24, 2009 | Tomtom ONE 3rd Edition GPS
How do i get camera updates for my carrera x350
you can only get updates for the binatone carrera x350 from Navteq.com as the mapping softwear is from them. You have to pay a little for them but all the updates and traffic cam's etc are here for you to find. Hope this helps
Jun 13, 2009 | Toymax Binatone Carrera X350 Car GPS...
Binatone carrera x350
Jun 28, 2008 | GPS
Toymax Binatone Carrera X350 Car GPS Receiver Logo
220 people viewed this question
Top Toymax GPS Experts
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Toymax GPS Expert? Answer questions, earn points and help others
