Sony kv 32526 tv
Fuse for power?
    Problem Solver:
  • 6 Answers
4amp/250v,check first if theres a short
Posted on Apr 08, 2008
On my 2004 trailblazer i have no power at my power fuse under the rear seat there is also no power for the 4wd ans brake fuses what do they get there power from
no power at my power fuse under the rear seat ??? Do you mean the whole rear fuse box is dead . Or just a single fuse ? What number fuse an how many amp's ? Under hood fuse box I/P BATT fuse number 48 125 amp ,this power's the rear fuse box.
Nov 18, 2017 | Seat Cars & Trucks
No power to memrey wire for stero
In the engine fuse compartment... .check fuse #3 (10 amp fuse) to see if you have power to the fuse and coming out of the fuse. If you have no power coming from the fuse, suspect a blown fuse or a broken wire between that fuse box and the radio... if there is no power to that fuse. Check the Maxi fuse number 6, a 30 amp fuse.
Aug 14, 2012 | 1998 Ford Expedition
88 acura legend cigarette lighter and interior lights dont work and the fuse is good
Check for power at the fuse with an electrical ciruit tester if there is power at the fuse its a short after the fuse if there isn't power at the fuse its a short before the fuse. If its before the fuse it maybe easier to find an open fuse with power and switch the line out of the fuse block to the new Location
Jan 05, 2012 | 1988 Acura Legend
How to replace power steering fuse
hi 8, you can follow these steps:
1. Open the fuse panel of your car,There are two fuse panels. The fuse for the power steering fluid is located beneath the hood, on the right hand side behind the battery. Open the fuse panel by pushing two side levers inward and lifting up.2.Locate the power steering fuse. On the inside lid of your fuse panel cover there will be a fuse diagram. It shows you the location of your power steering fuse, which is the fourth fuse in the top fuse bank.
3.Pull out the blown fuse using the needle-nose pliers
4.Slip the new fuse into the empty fuse slot, then replace the fuse box panel
good luck
Nov 29, 2011 | Cars & Trucks
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
Where is the power fuse located
fuse is located at the power supply section.to get to the power supply you need to remove the back cover of your monitor..after you remove the cover you can see the power supply..and the fuse is place on the pcboard and there are two fuses the primary fuse and the secondary fuse....be careful when replacing the blown fuse...do it only once once you replace the fuse and blown again there is a problem on your power supply...replace your power supply with a new one...
hope this could help you...goodluck!
your rate is important to this help tnx..
May 11, 2010 | ViewSonic N2751W 27 in. LCD Television
2005 pathfinder, Brake lights, power at the fuse,
are you checking power with fuse in and to one side of the fuse or to both sides if to one side you will have power if to both side you shouldn't have power your fuse is blown. Your fuse is there to protect the device and wiring from burning up fuse blows cuts power off
Sep 01, 2009 | 2005 Nissan Pathfinder
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
May 13, 2009 | 1992 Ford Ranger
F 450 instrument cluster has no power and is inop need to trace wires to power source
Interior fuse box fuse no.33(15amp) supplies power in run/acc postion to BK/PK wire pin 19 of cluster.
Interior fuse box fuse no. 45(10 amp) supplies power in the start or run postion on the RD/YE wire pin 20 of cluster.
Interior fuse panel fuse no. 41(10amp) supplies power to the battery saver relay on LG/OG wire pin 11.
Interior fuse panel fuse no. 35(10amp) supplies power to interior lamp relay on BK/LG wire pin 12.
The last 2 are hot at all times.
Apr 11, 2009 | 2004 Ford Super Duty F 450
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
