Question about Canon PIXMA IP5200 InkJet Photo Printer
Does not switch on after power off - Canon PIXMA IP5200 InkJet Photo Printer
  • Canon Master
  • 12,061 Answers
Can AC and DC Power Modules Be Used in the Same Switch?
Fixed Switches Product Series Model AC and DC Power Module Mixing S3700/S5700/S6700 S3700-26C-HI Supported S5710-28C-EI Supported S5710-52C-EI Supported S5700-28C-HI Supported S5700-28C-HI-24S Supported S5700-EI (non-PoE) Supported in V200R005 S5700-SI (non-PoE) Supported in V200R005 S6700 Supported in V200R005 S5710-HI AC and DC power modules cannot be used together, but 350 W and 1150 W AC power modules can be used in one switch. S5720-HI Supported Modular Switches · When a switch does not use a PoE power module:
AC and DC power modules cannot be used together in the same type of power slots. Power modules with different power values cannot be used together either.
· When a switch uses a PoE power module:
Version PoE Power Module System Power Module V200R005C00 and earlier versions AC AC DC power module not supported - V200R006C00 and later versions AC AC DC DC AC DC ·
AC and DC power modules cannot be installed in the slots of the same type (system or PoE) in the same switch, and the power modules of different power values cannot be used in the same switch.
S5720 Switch Thunder link com
Oct 27, 2016 | AC Cars & Trucks
Driver door will not work lock or windows
They hooked into wiring they shouldn't have >
Power Window System Components
The power window system consists of the following components:
Driver door module (DDM)
Passenger door module (PDM)
Body control module (BCM)
LR power window switch
RR power window switch
Window up and window down relays in each of the rear passenger window switches
Window lockout switch
Reversible power window motors in each of the doors (circuit breaker protected)
LT DOOR CB 25A (System power for left rear window)
RT DOOR CB 25A (System power for right rear window)
Power Window System Controls
The power window system will operate anytime the retained accessory power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The DDM contains 4 power window switches which are integral components. Closing any of the normally open, rocker type switches provides the DDM with a request for power window operation. The switches for the 2 front windows have 3 positions Up, Down and Express Down, while the switches for the rear windows have only 2 positions, Up and Down. Each of these switches and their positions is a direct input into the DDM. Upon receiving a request for power window operation, the DDM, transmits a class 2 message indicating the switch and it's changed position.
The PDM contains a single power window switch that is an integral component. Closing of this normally open, rocker switch provides the PDM with a request for the front passenger power window operation. The switch for the front passenger window has 2 positions Up and Down. Each of these switch positions is a direct input to the PDM.
The 2 rear passenger doors have there own switches. Each of the switches contain a power window up and down relay. A switch activation alone can control the up and down functions of the rear windows. However the BCM, upon receiving a class 2 message from the DDM, can control the set of relays which will activate the rear window motors.
Jan 10, 2016 | 2004 GMC Envoy
Is there a fuse for the window switch
Which window switch ? RT DOOR CB-circuit breaker , do you know what a circuit breaker is ? 25A (System power for right rear window)
If you not sure about any of this I suggest you take your vehicle to a ASE certified repair shop .
Oct 08, 2015 | 2002 Chevrolet TrailBlazer
How can i start my desktop without front panel power button switch?
The power switch on desktop computers is a momentary-contact type switch. Pressing it makes contact and releasing it removes contact. Because of that, it would be impossible to wire up a situation where the unit will power up with power supply. Luckily, it is fairly easy to "replace" a bad power switch. If you open your desktop computer and observe the rear of the power switch, you will see two wires coming out of it They go to a plug that connects to two pins on the motherboard. You can purchase a momentary action single-pole switch at any Radio Shack. There is very little voltage or current to deal with so any light duty switch will do. With power remove from the PC, clip the wires you traced from the power switch (do not confuse them with the Power LED light) at attach them to the wires from switch you purchased. Apply power and test operation. After testing, you can make a small hole in one of the removable panels for expansion drives and mount the new power switch! It will work just like the original.
Sep 18, 2014 | Computers & Internet
.power window is stuck in the down position. how do i fix?
2 things here.. 1. the switch is bad 2. the window motor is bad. remove switch panel. with a om meter or a 12v power tester check the switch for power, if it has 12v power push the switch into the up position and check to see if the power is feeding through the switch to the motor.If the switch has no power coming to it check the wire connections to the switch, follow back the wires to find out where the short is. 2. if the switch passes power to the motor you will have to remove the door panel and replace the motor.
Aug 17, 2014 | 2000 Ford Taurus
Power seat will not move forward or backward
check seat switch for power with test light then check seat motor for power using switch. If power at switch and not going to seat then switch is bad. If no power to switch then check power lead and trace back to supply point
Mar 09, 2011 | 2004 Kia Sorento
My right rear fog light does not work, any ideas why? the other lights work fine, and its not the light bulb
check for power at the light, if no power and fuse ok check for power to switch and power coming out of switch when switched on if there is power to switch but no power out from switch when switched on, switch is faulty, if there is power from switch, wire is broken between switch an fog light
May 27, 2010 | 2003 Porsche Boxster
No power at all
Power problem your side due to power fluctuation switch goes damage please check your power connectivity there is some problem with power.
May 07, 2010 | Allied Telesyn (AT-3624TR-19) Networking...
I recently bought a 2002 Pontiac Sunfire SE for my grand daughter as a High School graduation gift. Now the power windows won't go up or down. What could cause this problem? Hoping it is something simple...
This is One with the Power Window SWITCH in the CENTER Console they Often Get Liquids SPILLED on them Causing them to Fail, I Would First Check for 12volts @ the Switch with KEY ON. With a Sure 12volts Going IN the Switch Check for 12 Volt going OUT, If Switch IS BAD there Will be NO 12volts Coming OUT With this Go on to Switch Replacement
REMOVAL PROCEDURE
  1. Use a flat-bladed tool in order to remove the power window switch bezel (1) from the console.
  2. Remove the electrical connection from the power window switch (2).
  3. With a flat-bladed tool release the power window switch (2) tabs, and remove the switch from the power window bezel (1) retainers.
INSTALLATION PROCEDURE \
  1. Install the power window switch (2) into the power window switch bezel (1) until fully seated.
  2. Connect the electrical connector to the power window switch (2).
  3. Install the power window switch bezel (1) to the floor console.
((((>>>All of this is Assuming that All FUSES Related to And RELAYS Related to Windows Have Been Deemed GOOD & Funktional<<<<)))
If Further HELP / SUPPORT / INSTRUCTIONS Are needed P L E A S E Dont RULE me Out as I have the Answers, Just Try to be as Spisific as Possible and I will be More than HAPPY to Help you With your Needs of Auto Repair
Jun 15, 2009 | 2002 Pontiac Sunfire
Heater blower switch does not work.the switch is new also the resister is new .fuses on side panel check ok.what do I do next
Do you have power to the switch? Do you have power to the fuses? They may not be blown but they may also not have power. Not a likely scenario but possible. First look for power to the switch. No power trace to fuses. Next check if switch is getting power doe switch send power. Does blower motor receive power after you verified that switch has power. Is the switch from the dealer or a/m? Try these things first. If the switch is used than the switch is probably bad. Also there is a resistor on the blower motor that can go bad and that could be the problem.
Jul 29, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Canon PIXMA IP5200 InkJet Photo Printer Logo
251 people viewed this question
old marine
old marine
