Question about Epson Aculaser C1100 Printer
Service req e547 - Epson Aculaser C1100 Printer
  • Epson Master
  • 12,061 Answers
I can tell you that a Engine Service Error Code #E526, stands for a "SOILED ADC SENSOR". ADC stands for "Automatic Density Control" [sensor]. Hopefully, you will have your printers "User's Manual/Owner's Manual" and it will show you exactly where that ADC Sensor is located, because I do not know. I think its a removable board, that probably slides in and out, somewhere near the upper right section on the inside of the front of the printer. If you use the round knob [on the inside of the printer, near the center] as the center of a clock, then I would guess that the sensor board assembly would be around the one-o-clock to the two-o-clock position, but really don't know for sure...Basically if there are any parts of wrong specifications used, improper mounting, damage, distortion, dirt, or adherence of any foreign material, that can cause that particular error code. Hopefully the ADC Sensor is just dirty and needs cleaned. The major parts that need to be checked, are the "ADC Sensor Assembly", the "Main Harness Assembly" and the "MCU Printed Circuit Board". E532 error means there's a drain on one of the several motors within the printer. Reseat all the consumables within printer (especially the waste toner)and the paper tray the error clears. If the error doesn't clear then you have a real hardware fault and the job of changing each motor until you get the right one. This particular printer has a problem with waste toner. The toner seems to clog up and be the main cause of this error - you may find this occurs after the printer has been sat idle for sometime i.e. after a weekend. Once this particular printer starts giving this message its best to run through this routine each morning... open the front cover, unlock the two lockovers, pull out the consuambles about half way and then slam them back in - hard enough to loosen the toner but not hard enough to break the printer. Switch it on and it should remain error free all day.
Posted on May 27, 2010
Service req e 406 -
I'm going to assume you have an epson 406, and that you got a "service req" error. Means, "service required". There should be a code, too, that might tell us what service is required, but without that, we can do little for you.
Jul 15, 2016 | Office Equipment & Supplies
Service req 0001001C
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
Jan 18, 2013 | Epson Stylus Pro 10600 InkJet Printer
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error in printer
" Service Req E 0003" means that your printer needs to be serviced. Pls contact your service provider.
Jan 27, 2009 | Epson EPL N1200 Laser Printer
Need to reset error code E547 on Epson AcuLaser CX11N
E547 is a feed motor error, usual culprit is a faulty solenoid. You will need a technician to check all wiring & replace faulty part I'm afraid.
Jan 10, 2009 | Epson Aculaser C1100 Printer
E547
E547 = Feed Motor Failure
This means that the feed motor is not turning at the correct speed - or at all. Check for problems in:
HARNESS-ASSY FEED MAIN
DRIVE ASSY FEED
PWBA TRAY 500
HARNESS-ASSY FEED 1
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Service manual is available HERE if you need it
Jul 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Paper jam and E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson.
Jun 15, 2007 | Epson Aculaser C1100 Printer
E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson. Check my previous post on this item: http://www.fixya.com/support/t154259-paper_jam_e547
Epson Aculaser C1100 Printer Logo
914 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
