Question about Dewalt DEWD28110 Heavy Duty 4 12" (115mm) Small Angle Grinder
Fault on a Kinzo 115mm Angle Grinder
I have a Kinzo 115mm Angle Grinder. When I was using it on a job I got carried away and eventually brown smoke came billowing from the Grinder. It no longer works could anyone suggest what is likely to be wrong with it?
  • 1,498 Answers
Hi J,
Hopefully you just wore out the brushes. Replacement kits are available for a few bucks and the fix is pretty easy.
On the darker side, If it overheated enough that it burned the windings (insulation melts, shorts, badness), there isn't much you can do unless it's still under warranty.
You won't know until you get it apart. You'll know which it is at a glance.
Unplug it and dismantle the base of the grip where the cord is attached.
The brushes are small spring loaded graphite blocks that transfer electricity to what looks like a cylinder around the central drive shaft that has a lot of vertical copper strips on it. They are normally housed inside small copper tubes opposite each other.
If those tubes are empty but for the spring, it's brushes.
If the insides are full of ashy residue, it's not the brushes
Best regards and I hope it it's the brushes
Mike
Posted on May 27, 2010
Testimonial: "Excellent-many thanks."
Grinder makes a scraping sound
They all make a funny growling noise while they're running. It's just a rough fit in the gearing.
Jan 25, 2014 | Dewalt D28110R Heavy-Duty 4-1/2" 115mm...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Do you have a basic training course and knowledge assessment for 115mm and 230mm angle grinders
Hi, a good place is youtube, there are videos on most tools and some very good tips.
Oct 01, 2010 | Clarke Power Products 7 in 9 in Angle...
Makita Angle Grinder not working
check inside for any loose connections plus check the brushes. if like you say it is smoking it could be a trip to the wheelie bin for that one.
Jul 29, 2010 | Makita Angle Grinder 4.5" 9524NBX
I have a Dewalt Angle Grinder (4 1/2'' D28402) Checked that I have the O rings and don't see anything missing....don't know why but blade won't tighten down (unless I put the tightening wheel, wheel side...
What do you mean wheel side out? It should look just like the picture, the nut side of the disc threads on first. Depending on what disc you want to put on you may need a spacer that goes on first and then a threaded washer on the outside.
Jul 08, 2010 | Dewalt D28402 412" (115mm) Small Angle...
Disc flies off when grinder stops
yes the above is correct with the question "are the threads the right size." but it can also be because u are not slowing the grinder down before stopping it. if the grinder stopps to soon the disk will stay moving. so the disk will fly off. i had the same problem with a pnuematic grinder. sometimes it is the operaters fault not the tools.
" an object in motion aloways stays stays in motion till an outside force dissrupts it."
Jan 10, 2009 | Metabo W6-115 606111420 4 1/2" Angle...
Dewalt DEWD28110 Heavy  Duty 4  12" (115mm) Small Angle Grinder Logo
233 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
