Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Seagate Barracuda external hardrive - damage to usb connector on
I have a Seagate Barracuda external hardrive. The Drive has been working but i accidently put the USB connector cable in the wrong way and this has damaged the connection pins on the hard drive case. My pc can therefore not read what is on the drive. Can I remove the hard drive and insert it into another case (I do have another barracuda external hard drive) and se that.? Alternatively can I also remove the drive from the casing and connect it to my pc via a hard drive caddy? Thanks in advance
    President:
  • 3,085 Answers
Yes you can, to all of the above. It's just a standard har d drive in the case
Posted on May 27, 2010
  • 258 Answers
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
Recover data from seagate barracuda 7200.10
External hard drive case, which comes with its own PSU AC/DC power pack.
They come in IDE and SATA flavours, some with extra cables to convert IDE<>SATA.
Take HDD with to computer retailer so physical dimension can be matched.
Sep 07, 2012 | Seagate Barracuda 7200.10 ST3160215AS -...
How can I convert a Seagate Barracuda 7200.7 (Model st380011a) to an external drive with usb?
BUY A HDD ENCLOSURE (http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=2777&name=Hard%20Drive%20Enclosures)
Apr 09, 2012 | Seagate Barracuda Model ST380011A 80GB IDE...
My computer's hard disk seagate 40 Gb is damaged but it will show in bios set up . how can i recover my data back plz tell me.
The best way to recover your data if you cannot boot up your computer. Remove the hard disk and attach it to an USB hard drive adapter. Plug this adapter into a working computer's USB port and this computer should see this as an external storage device. You can then open the folders and files to backup/copy, provided the hard drive is not faulty.
Aug 12, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
How can i solve this problem..? my 500gb hard disk damage... the bios says that the 3rd master hard disk error.. pls.. help me..
I myself would purchase the external USB empty SATA Hardrive interface box and then connect it to your PC to see if it at least recognize the drive.
If you really need the files from the drive if this tactic doesn't work then I would find a Data Recovery company that can pull your information off the disk and send it to you. 'You will loose the drive but recover the information'.
Not cheep at all. Usually 3 to $400 charge.
Blessings,
A/V Media Guy
Nov 22, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How do to install slave drive Seagate Barracuda 7200.9. Does it has to be to the motherboard or to a card in my computer? How do I set the pins in what order?
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Oct 28, 2009 | Seagate Barracuda 7200.9 ST3400633A 400 GB...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
Problem hardrive barracuda 7200.7 160G: the led
I am thinking external HDD?? Bad power supply or check the connection.
Jul 19, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
No power on psu when Hardrive connected
Yes, I actually experienced it too about 2 months ago. I believe there is short in the board. I have a 200gb barracuda that failed (too soon) and I swapped the boards...just to see what would happen. I was able to recreate the other drives problem and vice-versa. I think if I could get my hands on a working barracuda(if there are any) I could recover my info. curse of the 7200.7's Good Luck, Tim
Feb 13, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
242 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
