Question about Fisher and Paykel GWL11 Top Load Washer
Top load washing machine
Motor makes grinding noise
  • Fisher and P... Master
  • 12,061 Answers
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
SOURCE: Tub gets off balance and makes noise while washing.
It probably does this because you have overloaded the machine with towels or bedding try putting less in...
Posted on Jan 03, 2009
onthejob5130
  • 640 Answers
SOURCE: agitator grinds and won't spin
remove cap,,or fabric softner dispencer..pull straight up..look down in the agitator you will see a plastic cover,,pull it straight up...now your looking at the agitator dog cam assmbly..thats a 1/2 in nut there,,remove it you will need a nut driver or wrectet...now just pull the hold agitator up...be careful not to lose the agatitor dogs..onthejob
Posted on Jan 17, 2009
SOURCE: direct drive washing machine will
Replace the coupler between the motor and the geqr box, a 15.00 part
Posted on Feb 08, 2009
SOURCE: maytag pavt234aww
I had to replace the pump assembly, the pulley has a bushing in it that was working its way out and rubbing against the base plate of the machine.
Posted on Feb 14, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Machine won't drain, or spin and makes a grinding noise
This problem sounds like it could be serveal different thing. A motor that has a broken coupler will make a grinding sound. This machine does not use a belt. A gearcase can aslo make a loud noise when defective. Once I found a wire bra inside a pump and it made a grinding noise. All these things must be check in order to figure out what and where the problems lies.
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Grinding noise in top load kenmore washer when agitating
IT COULD BE A FOREIGN OBJECT IN THE PUMP. THE ONLY OTHER ITEM WOULD BE THE DRIVE COUPLER LOCATED BETWEEN THE MOTOR AND THE TRANSMISSION.
CHECK THE PUMP FIRST. IT IS ATTACHED TO THE FRONT OF THE MOTOR WITH TWO CLAMPS.
Apr 13, 2008 | Kenmore 22422 Top Load Washer
Machine wont wash
needs a new motor coupler. small round rubber piece between the motor and transmission. easy to replace
Oct 29, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSC9355DQO won't spin and makes grinding noise
grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
Aug 22, 2007 | Whirlpool LSB6200KQ Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
671 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
