Question about Northern Industrial 2 Hp Twin Tank Electric Air Compressor
Why does my compreeor switch release the air after reaching the required pressure instead of holding the air at the required pressure??? I've just purchased and fitted a new automatic cut off switch to my compressor! you can set the switch to cut out at whatever pressure you require, however no matter what pressure you set it to cut out at, it releases the air from the tank when it cuts, out untill the air pressure drops to the where it switches the pump back on to build up pressure again! Why is it releasing the air after the cut off switch switches the pump off instead of holding theair to maintain the pressure???
  • 843 Answers
There are two valves in play here. There is a relief valve that opens when the motor kicks off to release the pressure in the compressor itself. That is normal, and is required so that the motor can restart next time without having to overcome that pressure. The other valve is the problem. It is a reed valve between the compressor and the tank. This valve's job is to prevent the air in the tank from returning to the compressor. Think of it as a ratchet for the air. It is this reed valve that has failed.
Posted on May 27, 2010
    Sergeant:
  • 462 Answers
Its usually called a downloader valve
Posted on Dec 10, 2012
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Mac 5200 pumps pressure to 140lbs. then blows off pressure until 120lbs is reached. Cut in is about 115lbs. I have replaced main switch and it still does same. Tried small adjustments on mainswicth st
Check your Safety Valve. It is on the back of the tank sometimes on one of the pressure switch ports or on the air manifold. It has a ring on it to pull to relieve pressure from the tank. The spring in these can get overheated so they don't hold air unless the tank gets over 165 psi. When the motor is running hold the center pin in to see if you have the same results. If the valve holds air until you let it go, replace it.
Jan 30, 2012 | Makita MAC5200 Electric Powered Air...
Compressor won't restart when pressure gets low. How do I fix it?
The unloader is designed to release the pressure in the discharge tube after the unit reaches set pressure. The unloader is usually located within the pressure switch and is enabled with a small lever opening a valve (some look like tire stem). You can verify if it is working by cycling compressor and listening for release of air after unit reaches set pressure. Some compressors do not have a built-in unloader relying instead on loose fitting parts to bleed out air. On these units, air leaking back from the intank checkvalve will cause problem of loaded/backpressure and the motor cannot overcome. Easy to verify if checkvalve is leaking; with pressure in tank remove the discharge tube at the checkvalve and spray soapy water. Clean or replace this valve as needed. Good luck
Apr 20, 2011 | Campbell Hausfeld Air Tools & Compressors
A/c starts after it reaches required load it shuts off and when it is suppose to start again it just humms and it trips the circut breaker
It sounds like the small valve that releases the pressure out of the main pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch. If the valve appears to be working then it means that the Non-return valve on the input to the tank is not sealing properly and letting air back into the main pipe causing the compressor to start under load. Check both valves for correct operation and replace as necessary.
Sep 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My small pro force reaches a certain pressure and then releases the air instead of stopping
hi, sounds like the safetyvalve is opening. there is a opening value on the valve, check this at moment of opening. if it opens at correct value, your pressure regulator is set to high. to lower this you have to open the regulator, (is the small case where the wires going in) and release the bold in the spring.(unplug first before opening, life parts) if the problem stays the same, make sure that the pressure out of the tank will reach the regulator. there is a small hole witch can be closed by rust or dirt. good luck, you can always aske for more options.
Mar 01, 2010 | Coleman Proforce 6 Gallon Air Compressor
Keeps on cycling on and of when not in use?
I believe you have a faulty pressure switch. The black hose reports to the switch what the pressure is and either starts or stops the compressor through the switch. Air is bleeding out of the hose ...causing short cycling ... for some reason. Fix the leak - fix your problem
Thanks for using FixYa.com
positive comments always welcome
a
Oct 27, 2009 | Hitachi EC12 Portable Electric 2hp Air...
DeWalt emglo compressor does not start
hello,
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 psig.so after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur switch.you have defective pressure switch,regards rate me,thanks
May 02, 2009 | Heating & Cooling
Once compressor reaches 125 lbs. pressure, the relief valve opens and releases pressure. the motor then tries to engage but cannot come to full speed because of back pressure I am trying to find and...
Generally, the safety/relief is set to 140 to 160psi. The pressure setting is stamped on the side of the valve. Replace the valve if it will not hold stamped pressure(cost about $6 at Lowes Lumber).The pressure switch is usually set at the factory to 120 - 130 psi. The unloader part of the pressure switch will not release backpressure unless it reaches set cut-off. The 1/4 inch line attached to the pressure switch connects to air discharge tube at the intank checkvalve (brass valve). The safety valve should very rarely release pressure, only when pressure switch malfunctions and allows pressure to reach up to 160psi. The tank will hold over 300psi so dont worry about the 160psi safety. I am not sure about your exact model number or brand, however most small compressors work the same and share similar parts. For manuals to other similar compessors to to www.dewalt.com. Here you will find manuals to dewalt and porter cable compressors. I prefer to use generic replacement parts from www.grainger.com or from Lowes Lumber. These parts will cost less than factory replacement. If you need to replace the pressure switch, use SquareD brand from grainger. Watch fitting sizes and pressure range. Good Luck on your repair.
Apr 03, 2009 | Northern Industrial 2 Hp Twin Tank...
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Coleman 5Hp Compresser
All electric compressors share a basic design with ac power pressure switch with unloader and checkvalve between the pump and the tank. When the pressure switch powers off, it unloads the compressor by releasing the air in the discharge hose. You will notice a small tire stem pin and a lever to engage it somewhere on the pressure switch. If the compressor stops before reaching set cutoff point, the air pressure remains in the discharge hose not allowing the motor to start, thus the hum you hear. Solution is to check for the proper function of pressure switch /unloader, tank check valve (if check valve leaks air back to compressor it will load motor causing hum) and extra measure check capacitor for at least 90% of rated valve. Finally, do not run this compressor with an extension cord, use more hose instead. enjoy
Oct 22, 2008 | Coleman CP0302013 20 - Gallon Portable...
Northern Industrial 2 Hp Twin Tank Electric Air Compressor Logo
714 people viewed this question
Top Northern Industrial Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Air Tool and Compressor Expert? Answer questions, earn points and help others
