Question about Playskool Busy Ball Popper
Hello I was wondering if I can get a new top ramp for my babies ball popper? Thank Jus
  • 3 Answers
Yes you can. Call 1-800-PLAYSKL and order the bowl or the track for just $4.00 including shipping.
Posted on Aug 12, 2010
NEED TO REMOVE CLUTCH CABLE FROM CLUTCH
Loosen the clutch cable adjuster and increase the slack in the cable. Remove the jesus clip on the bottom of the clutch perch at the handlebars. Push up on the pin that holds the cable in the clutch perch and remove the pin. Pull the top end of the cable out of the clutch perch. Remove the trans side cover. There is a ball and ramp attatched to the inside of the cover with a retaining ring. Push the ramp all the way to the front, turn the cable 180 degrees and remove it from the ramp. it is easier to do this if you remove the retaining ring, then take out the ball and ramp. Be careful not to loose the 3 ball bearings! Unscrew the cable from the trans cover and you are done. Installation is the reverse of removal. When reassembling the ball and ramp, it is easier if you put grease in the indentations for the ball bearings, to hold them in place. Before reinstalling the trans cover, make sure the ball and ramp are pushed toward the rear of the bike.
Aug 05, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
I am replacing the Wheel bearing on my 2003 Mazda 6, I am wondering how the lower Ball Joints seperate, I have everything else loose and just need to be able to remove lower ball joints before taking the...
you need to use a ball joint popper. this way damage the rubber on the ball joint so make sure u fill it full of grease when your done or replace the ball joint
Mar 27, 2012 | Cars & Trucks
Where can I get replacement balls for theplayskool busy ball popp
Go to the hasbro playskool website, select the customer service tab, in the alpha list select b, scroll until you come to busy ball popper. once you click on it it will give you an option of an order form for Canada.
Feb 04, 2010 | Playskool Busy Ball Popper
The fan doesn't work (most of the time)
when waiting a year to try it out , you get what you got and can not complain about it . try a new battery
Oct 18, 2009 | Playskool Busy Ball Popper
Hi--no air in Busy Ball popper
I had the same problem!! Music worked, but fan just stopped running... Since my kids love their busy ball popper I was determined to find a fix!!
The solution for me was to replace all 4 batteries with identical brand batteries.
When the original batteries had puttered out I replaced them with 2 brand new Duracell and 2 brand new Energizer batteries (because that's what I had on hand). The popper worked just fine and I'd say a few weeks later the fan just stopped working. Music played, but no fan. I thought the fan motor must have gone bad, so I searched for another popper at a resale shop (hoping to salvage the fan motor). Well I found one, but didn't end up using it because I discovered that putting ALL the same brand of batteries in my popper did the trick. The batteries weren't necessarily brand new, but they were all the same brand and I would guess the same "age". Anyway, I'm just glad it all works now (music and fan) and my kids are back to their ball popping fun. If you haven't already give this a try. Otherwise I have a spare ball popper if you need any parts! Good luck!
Oct 13, 2009 | Playskool Busy Ball Popper
Hello, my car has recently failed its MOT on the offside (drivers) ball joint and was wondering if you could please help me. I've heard bad things about the garage i am using and i am therefore doubtfull...
Ball joints can have wear without producing any noise. Even slight wear will be classed as an MOT failiure because ball joints are a critical component. The only way to check if the work has been done is to inspect the car afterwards. A new ball joint should stand out because it will be spotlessly clean. If you turn the steering fully to the right the ball joints may be visible or they may be obscured by the wheels. It is much easier to see them when the car is on a ramp. If you have not had the work done yet you could ask another garage or tyre fitter to check the ball joint for you. It is advisable to have your tracking checked after changing a ball joint. Some tyre companies will check the tracking for free and charge only if they have to adjust the tracking. Hope this helps.
Oct 08, 2009 | 2001 Ford Focus
Need replacement balls for Busy Ball Popper
Hi, I purchase from amazon last time for my kid. here: New 1st Steps Collection by Shakira Fisher Price. You can find them for 4.5$ and above... I hope I have helped. cheers
Mar 26, 2009 | Playskool Busy Ball Popper
Playskool Busy Ball Popper Logo
63 people viewed this question
Top Playskool Toys Experts
pawnpower
ray gallant
Tom Chichester
Are you a Playskool Toy Expert? Answer questions, earn points and help others
