Question about Technics SA-DX750 Receiver
Code f70 . fuse is ok.what is next.... - Technics SA-DX750 Receiver
  • 4 Answers
- if you've got any knowledge of takin these type of things apart then here goes. undo the six fixing screws (if it outs of warrenty that is).
what you'll see is a main board and a little pcb boad attached to the back in which the rca's are connected to. remove the screws that hold this in place and with a set of long nosed plyers gentlely close the plastic lugs so you can remove it ( also remove all wires as to remove it compleatly) if you look on this little board you will see 2 black chips that are next to each other. the 1 that stands out the tallest out of the pair CHECK IT FOR DRY JOINT (solder split ) as that 1 normally becomes loose and can move about (re solder it) and replce back. now on the main heat sink unit you have 2 amp chips. remove the screws and clean all heat sink compound. put new compund on and screw back ( these dont need removel if your gentle. replace the cover and see what it does
best of luck
Posted on Aug 13, 2010
Its showing F70 error on display. Only workd on DVD mode, when i turn it on any other mode it just shows F70, switch power off. All fuses are ok, no any visibly damaged components
The fuse is a part of the problem it is for safety measures
the problem is in between the power supply regulators, capacitors and power amplifier circuit board.
usually a regulator or an output transistor can cause this error.
hope this helps.
Aug 08, 2014 | Panasonic SA-HE70 Receiver
AV CONTROL RECEIVER SA_HE7 F70
F70 error checking fixed contacts fuses.
Oct 04, 2013 | Panasonic SA-HE7 Receiver
What does f70 overloads means
Sounds like either an amp problem or a fan problem. Either one can send a F70 code. Check and see if the rear fan is turning freely, it might just be dirty and can't spin easy
Sep 22, 2013 | Panasonic SA-HE70 Receiver
I have a Technics SA - DX750 Amp Everytime I turn it on I get an error message F70 and then it requests that I turn the power off. This is all it does now, so sound. How do I solve this issue I have...
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Technics SA-DX950 Receiver
What does the code f70 on a kenmore elite dryer mean?
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Please report back here what you find, OK?
Aug 05, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
F70 problem
Look up "Panasonic F70 error" on Google and you will find plenty of discussion about this problem.
The F70 is a blown fuse error. It looks like you can can the fuse yourself, if so inclined, otherwise send it to a service agent.
Aug 03, 2008 | Panasonic SA-HE70 Receiver
Panasonic SA-HE100 5.1 system error code F70
According to the operating instructions, you must take it to a repair facility. There are no troubleshooting suggestions for this problem in the manual.
Dec 15, 2007 | Panasonic SA-HE100 Receiver
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
Technics SA-DX750 Receiver Logo
822 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
