Question about Dometic Rooftop RV Air Conditioner
I have a Dometic 579 Series Brisk Air AC. The model Number is 57915.531. When I turn the fan on, nothing happens. If I reach up and turn the wheel blower the fan will start up and everything works. I replaced the fan motor and put on a new capacitor part # 3100248.412 was supplied. The fan still will not start on it's own. I still need to turn the wheel blower to get it started. Help!
  • Dometic Master
  • 6,674 Answers
My sheet shows part # 3100248.420 as fan run capacitor.You may have an updated number. Check voltage outputs labeled on it are same as on old one, and double check wiring is correct, to and from capacitor. Be careful not to mistake compressor start capacitor as well. By sounds of number, it's probably the right one.
Posted on May 27, 2010
Testimonial: "Thanks, your number is correct."
3 Suggested Answers
  • 34 Answers
SOURCE: Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Posted on Aug 11, 2009
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
I have a Dometic 15K roof Ac on my FW. After the AC reaches therm temp, the compressor and the fan turn off, but the fan starts right back up again and runs until you set the thermostat on off.
That is normal operation, only the compressor cycles, the fan stays running to keep air circulating for better temp control. Otherwise the rear of the space could get 5 degrees warmer than the front
Feb 23, 2015 | Dometic 459516 459516.XX1C0 Brisk Air...
Dometic 579 Series Brisk Air AC runs fine-blower still runs but every couple minutes it "kicks on and off" it will blow hot air and then cold air and continues to do this. Did not do this until we...
sounds like it is skipping the motor I mean, I am assuming that it was replaced with the correct motor(rpms,hp,volts). As if it was not it will skip, like it is doing now.
Aug 28, 2010 | Dometic Rooftop RV Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
Quit blowing cold air
if a leak, should be repairable, a lot of techs these days find it easier and more profitable just to replace things. try a new tech
Sep 04, 2009 | Dometic Rooftop RV Air Conditioner
Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
Mar 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
735 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
