Question about ASUS M2N-MX Motherboard
I can't put on the 2 ram on slot2, the mon state no signal when both ram on.Is there any setting need on the bios.
    Master:
    Sergeant:
  • 383 Answers
No the only problem is that the board cannot handle that much ram
Posted on May 27, 2010
I can't use both sims at one time. when simcards are in slot1 & slot2 i can see only "sim1 - operator name sim2- empty" but every simcard is works good single in slot1 or slot2. But again i...
you will need to configure the cell to select both 1&2........on your cell (settings) choose both sims and you should be able to rename both sim cards
and even then only one sim will work at a time (yes you will get text and/or message on the other sim while using the other)
Apr 10, 2011 | Cell Phones
Help Finding The Best CPU For P4SD-VX Motherboard.
Brilliant, I commend you! I've posted using the simple CPU-Z program to several people on here, and they just don't seem to get it!
Sony doesn't release detailed info on their motherboards, for the most part. Just the usual generic info.
2.6 Volts?
Open CPU-Z again. CPU tab.
Let's see if you have this processor.
Name: Pentium 4 HT 2.6C
Code Name: Northwood
Package: Socket 478
Technology: 130nm
Core Speed: 2600.0MHz (Fluctuates when the computer is running)
Multiplier: 13X (Fluctuates when the computer is running. When the Core Speed fluctuates enough, the multiplier changes to match)
Bus Speed: 200.0MHz
Rated FSB: 800.0MHz
Voltage: 1.475 to 1.525 V (Fluctuates)
Click on the Mainboard tab.
Is the motherboard chipset Intel 865PE?
[Chipset: Intel i865PE
Southbridge: ICH5 or ICH5R
Motherboard made by Asus?
It may not have an Auto CPU feature in BIOS Setup then. Means you cannot just put any old processor in there. Have you been into your BIOS Setup yet?
SPD stands for Serial Presence Detect. This is used by BIOS to automatically detect what ram memory is being used, and the ram memory timings.
JEDEC was Joint Electron Device Engineering Council/s. Changed to JEDEC Solid State Technology Association.
One of the things they have done is to set standards for Ram Memory.
Voltages used and ram timings.
JEDEC 1 is the ram memory module, in Slot 1 on your computer.
(May state DIMM 1 on the motherboard)
JEDEC 2 is the ram memory module, (Stick) in Slot 2.
JEDEC set the voltage standard for DDR Sdram ram memory, at 2.5 Volts. Your computer has DDR Sdram ram memory in it.
The default voltage setting from the factory will be 2.5 volts for your computer.
Nov 16, 2009 | Office Equipment & Supplies
How much memory can this product of hp take i have cone some test and i think it should be up to 2gb per slots i have try to upgrade it to 4gb and fail i have even try 3gb and fail but it works with 3gb if...
If you are using the XP or Vista OS, if you are going to install more than 3 GB of Memory then it fails to show up on the computer properties.
Once you install the memory then you may check the BIOS for the memory installed in the system, the BIOS shows the exact amount of memory installed in the system.
You system is capable of 4 GB of RAM.
Sep 10, 2009 | HP Compaq 6720s Notebook
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Need a third break light for a 95 dodge ram an dont have much mon
Buy the light and put one wire to ground and run the other to the park brake signal wire and you should be o.k.
Apr 04, 2009 | Dodge Ram 1500 Cars & Trucks
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
MotherBoard Problem (BIOS)
im not positive this will work for you but in my bios there is a setting for USB keyboard and USB mouse and at one point I had to enable both of those to use my keyboard and mouse during the windows formatting process. Try to find settings like that for USB keyboard and enable them in your bios. If that doesn't work then you will have to use a different keyboard or get a usb to ps/2 converter. you might want to try unplugging your keyboard and then booting and see if it still goes straight into bios. If it doesn't then your keyboard is sending signals without you pressing the keys and that is obviously the issue.
Dec 19, 2008 | ASUS P4S533-MX Motherboard
Ram DDR2
Hi Terry, you're board, PC Chips P23G only supports a max memory of 2GB. Please check pg. 9 of your manual, Installing Memory Modules.
Please be noted you can NOT use DIMM DDRII 1~2 (DDR2 533/400) and DIMM DDR1~2 (DDR 400/333) simultaneously. Only use either DDR2(533/400) or DDR(400/333) memory modules! (You should check the spec's of the other board before inserting memory that may not be supported). (You can damage the memory)
Click the link listed below for you're PC Chips P23G board.
Suggest you save this link to you're favorites.
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=92&LanID=2&DetailID=387&DetailName=BIOS
You will notice there is a fix for:
Patch code to fix REALTEK clock buffer sometimes couldn't detect DDR2.
Once there, click BIOS. Scrol down to the bottom of the page & read special notes. Than click the drop down menu & pick a download site. Creat a folder on you're desktop to store the download. Uncompress the .zip file. You will than have a folder named 070115 & a ROM file named 070115.ROM
This bios flash program requires you to use a floppy disk drive to flash the bios.
Follow the instruction at this link to flash you're bios.
http://www.motherboards.org/articles/guides/42_1.html
If you find to hard to folow you can pick another from this google search site.
http://www.google.com/search?hl=en&q=how+to+flash+a+bios+&btnG=Search
Good Luck! & Take your time.
Have more questions, feel free to ask.
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | PC Chips P23G Motherboard
How to fit more ram
go into the bios.
You should have a setting that says Single channel or dual channel. Usually on the first page of bios.
If the problem persists, without being able to set the bios configuration. put 1 stick of ram in bank 1, and 1 stick of ram in bank 2.
Regards mike @ compurepair.
Mar 29, 2008 | Acer Aspire™ T180 PC Desktop
Ram upgrade
memory not compatable or ram port doesn't support 2 gig memory. It's all i can think of.....another thing you can do is....put old mem back...upgrade bios and try new mem again, and then if still not working mail manufacturer for reason. JJ
Sep 15, 2007 | Acer Aspire 3610 Notebook
ASUS M2N-MX Motherboard Logo
42 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
