Question about Mitsubishi WS-65809 65" Rear Projection Television
Hello well the blinks go 3 blinks then stops and 3 again,
  • Mitsubishi Master
  • 8,617 Answers
What that means is that the set doesnt recognize any shutdown error if it does 1blink short pause the 2 blinks, but if it does 2 blinks short pause the 1 blink thats an error code. can you dtermine which sereies of blinks it is?
Posted on Apr 07, 2008
SOURCE:
What is Code 33 on Onan Generator Model12.5 HDKCB11506B?
You may be reading the code wrong, Code 33 shows up as blink 3 pause blink 3. This means it has a lower level code fault. To access the real code. Press the stop button 3 times fast within 5 seconds and re-post what the code is please. It may blink pause then blink again, that is the lower fault code that will help diagnose the problem.
Feb 10, 2015 | Onan Generator, 4000W, Gasoline
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
I have a Mitsubishi WD-52725 and the timer light continues to blink and I cannot reset it. What can i do to fix this.
1. Timer LED does not stop blinking; suspect the DM PCB part # 934C152001-V28++ 2. Timer LED blinks 70 seconds, pauses then starts blinking again, suspect the E2P PCB part # 935D820001-V28+ 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition.
Feb 17, 2011 | Mitsubishi Televison & Video
HOW TO SET CLOCK
1. push the clock button 2. display should be blinking. 3. then push 3, then 0, and 0 again (this is for 3:00) 4. then push the clock button again, and it should be set     again. 5. sometimes, by doing just the first 3 steps and letting     it be until the blinking stops, is another way. But             most likely, you'll need to follow through to step 4
Mar 28, 2010 | Belling BIM60 Microwave Oven
How to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
30PW850 H99
maybe the system IC has getting defective, or sometimes looseboard. Need to resoldering.
Apr 09, 2008 | Televison & Video
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
