Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Hello. my printer always says paper size error but when I try to reset paper it says not available. may I get some help please?
Mix-it-up
  • 832 Answers
SOURCE: finding drivers to download for my dcp-350
http://welcome.solutions.brother.com/bsc/public/SearchResult.aspx?reg=us&TXT=dcp-350c&FLG=0&c=us&lang=en
and have a look around there (faq)
Posted on Apr 05, 2008
iservice
  • 318 Answers
SOURCE: paper error
Hi David.
Check the program you printing from.Change the paper size settings in your page setup to the correct paper size.Like in Word go to file and then to page setup.
If you printing from your network system program that is running with a print server ,you have to ask your network adminatrator to change that settings in the system program for you.
Make sure the paper tray settings on the printer menu are also set for the correct paper sizes.
I hope this may solve your problem ,if not let me know.
Posted on Nov 11, 2008
jqsababa967
  • 145 Answers
SOURCE: There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Posted on Apr 26, 2009
SOURCE: Paper Size Error: The specified custom paper size is not supporte
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Posted on Oct 20, 2009
SOURCE: trouble printing envelopes on kodak esp3 printer
Put a few small pieces of tape on the back on the envelope and tape it to the paper, print a test run of the adress and tape the envelope over the adress in the correct spot.
Posted on Feb 22, 2010
Everytime i print something in a label sized setting it always cuts into short
Before printing try using print preview first and adjust yur settings from there. Or go into control panel select printers and reset to default settings, restart your computer and try again. Good luck.
Sep 09, 2012 | Canon IP2700 Inkjet Printer
Hi,, i have an oki MC160n,, that has an error coming up after a couple of pages being printed.. it says "paper size error, reset paper (1lt) press start key" can you help me fix this please
Please check the settings in your printer that you have selected correct paper type and tray from which you are printing. Also while giving print command make sure paper size is same.
May 05, 2011 | OKI Office Equipment & Supplies
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
Tony
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
Paper jam error
your software doesn't have problems... its your printer itself or the way you put on the paper that's why its always having error....
Feb 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
673 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
