My projector keep shutting down
I changed my lamp on a Boxlight 17-K as the lamp incator was on and the projector shutted down. but after I changed my lamp the problem is still the same. The projector power-up then the lamp is on then everything shut down.
Can you help?
  • 2 more comments
  • steelerector May 17, 2008
    how do you reset the hours and clean the filter
  • jpbrad May 24, 2008
    I have an NEC LT240. I replaced the lamp and have attempted to clear th ehours meter numerous times. The "lamp error" is still flashing and the projector will not stay on for more than 60 seconds. When I turn it back on the lamp meter is expired again.
  • trem684 Aug 20, 2008
    I have a infocus LP 650 projector.I power it up ,the lamp goes off after 30 seconds.
  • Micky-Game Jan 10, 2009
    Look I dont know how to re-set the hour on the menu juste tell me please. [email protected] tell me how can I re-set the hour on the projector.
Noise comimg from back of tv
Posted on Jul 27, 2008
    New Friend:
How can i reset the lamp hours i am having same problem SHARPVISION XV-100
Posted on Feb 25, 2010
How can i reset the lamp hours and clean the filter? coz i am having same problem
Posted on Apr 12, 2008
  • Anonymous May 01, 2008
    i have dell 3400m projector and i'ved change the bulb but i dont know how to clean the filter... but after i change the bulb i am still having same problem....my projector kept shuttin down.. plz help
    Problem Solver:
  • 9 Answers
After replace the lamp. Please reset the lamp hours and clean the filter. It should work.
Posted on Apr 09, 2008
SOURCE:
Turned on the projector and it immediately shut down and now has no power
it seems that the lamp ballast is failing
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
[email protected]
Mar 09, 2014 | Boxlight Cinema 13HD Lamp
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
The projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Aug 09, 2009 | ViewSonic PJ556D DLP Projector
Boxlight cd-850m won't turn on
You must reset the lamp timer after you replace the lamp before the unit will turn on. Do this:
Power on the unit. On the projector's keypad, hold down the the two volume keys simultaneously for 10 seconds. At that point the LED will turn green. Now you can turn on the unit again and it should work.
Feb 12, 2009 | Boxlight CD 850m Multimedia Projector
Lamp shuts down after startup
it is the power supply/ballast. when you first turn it on, the caps on the ps/bal charge then discharge when the lamp is to strike. if the caps are dried out (from excessive heat), it takes a while to build a charge. so the power drain from striking the lamp brings the ps/bal into shutdown. after you try again, the caps are now up to full power and everything is fine. but every time you unplug it, you'll have the same problem. replace the power supply and ballast.
Dec 11, 2007 | Boxlight CP 19t Multimedia Projector
1,197 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
