Question about Boating
I have a Mariner 4hp outboard motor 4m 6EO s 116580. Am I able to buy a manual for this model in Australia?
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 101 Answers
SOURCE: need manuals for 1976 starcraft holiday 14
Check ur local library.
Posted on Oct 02, 2009
  • 95 Answers
SOURCE: outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Posted on Mar 13, 2010
  • 5687 Answers
SOURCE: Mariner outboard motor starts runs, then fuel
If you have carburetors your float is stuck. It can happen more than it should and if it is a smaller engine, laying it on its side can cause it.
You would have to look at the float and imagine which way to lay the engine down in the future. The float could also be bad. You would take it out and float it in Gas, not water to see if it sinks.
If this is a big HP outboard and injected your fuel regulator is bad.
Posted on Apr 06, 2010
SOURCE: how to replace water pump on a 1985 90 hp mariner
water pump replace
Posted on Mar 30, 2011
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Sep 11, 2016 | Boating
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
How do I get an Owners manual
try ebay also google it maybe amazon
Feb 13, 2015 | Boating
Gday,i have picked up a 14ft boat with a Mariner outboard 60HP 2cyl but theres no compiance tag or numbers to show exactly how old it is,the wireing is there but nothing is connected to starter switch...
Mariner Trigger Assemblies
60 3 1984-1990 6428681-D000749 68162A 3, 68162A 3, 68162A 6, 96455A 1, 96455A 8 134-6453 18-5797 60 3 1991-1997 D000750-OG589999 99021A 3, 99021A 5, 99021A 8, 99021A13, 99021A15, 99021A16 134-9021-3 out of stock - 65 3 1976-1979 4382057-4571651 68162A 3, 68162A 3, 68162A 6, 96455A 1, 96455A 8 134-6453 18-5797iboats.com
You can look at your parts and determine your serial number and year.
Direct link to the page
http://www.iboats.com/Mariner-Outboard-Electrical-Parts/dm/cart_id.556536444--session_id.729929016--view_id.268684
Mar 22, 2010 | Intex Mariner 400 4 Persons Boat Raft Set
Jun 07, 2009 | Boating
Mariner 4hp outboard can't get engine off casing
the drive shaft goes down through the water pump impeller and I suspect that the problem will be in the pump
the impeller is rubber and if run dry will melt the rubber into the housing and bind up the shaft
Brute force is a last resort so get all the information you can from a service dealer mechanic
Nov 12, 2017 | 2004 Mercury Mariner
Boating Logo
639 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
