Question about LG LSC183VMA Split System Air Conditioner
IDEC aircon E5 error what does it mean? - LG LSC183VMA Split System Air Conditioner
  • CGS Engineering
    CGS Engineering Apr 18, 2015
    Based on my Experience here at the hotel as a Air con technician i already encounter that problem and the solution for that problem is to replace the defective Fan motor. i hope it helps..
I am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
Posted on Apr 22, 2012
Waves AC E5 error problem pls solution.
Posted on Jul 03, 2011
    Problem Solver:
  • 11 Answers
Reprogram the cotrol unit,missing of supply of module control
Posted on May 27, 2010
Waves split ac e5 error rapear
  • Based on my Experience here at the hotel as a Air con technician i already encounter that problem and the solution for that problem is to replace the defective Fan motor. i hope it helps..
Posted on Apr 18, 2015
My ac general split I change new compressor but now display E5
Posted on Dec 11, 2014
C1 code for my aircon idec
I have an lg306g phone and need the un lock code and how I put the code in
Aug 26, 2016 | Cell Phones
My kolin 2.0 hp inverter series what does mean by E5 displayd code
Hi i am aircon tech, the problem of e5 is fan capacitor & relay connected the fan motor.
Jan 19, 2015 | Inverter Heating & Cooling
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
E6 error on idec
E6 error code comes for room sensor in this. It means there is any damage in sensor. Pls replace it
Oct 13, 2013 | LG LSC183VMA Split System Air Conditioner
E4 means what in idec
Voltage error?
http://waterheatertimer.org/How-to-wire-pin-timers.html
Add comment and give more information about timer, including which timer, voltage, and what you are wiring, and where E4 appears.
Feb 25, 2013 | RTO Idec Rte-p1ad24 24vac/dv Electronic...
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
Fairland aircon error code E5 what is wrong
E-5 Outdoor activation of compressor over heatprotection or motor lock.
Check out door fan motor mechanism locked, replace motor. If less rpm replace capacitor. If condenser coil dusty, clean it. If no gas/short of gas, do leak test and rectify. Thanks.
Feb 08, 2011 | Heating & Cooling
Mitsubishi aircon has e5 come up. whats the problem
e5- Remote control transmission error. Check wire correctly. Touch one of each of thevoltmeter probes to the terminals marked "R" and "C," tocheck for 24 volts of alternating current (24 VAC). If you do not get a voltagereading of 24 VAC, then the thermostat is not getting power. Reset the circuitbreaker, or check for a blown fuse, and replace if need. Use the voltmeter torecheck for 24 VAC between the terminals. If the thermostat still lacks power,check and reset any tripped condensate float switches. Check the power switchon the HVAC equipment and set to the "On" position, if necessary.Replace any broken wires and tighten any loose wire connections to restorepower to the thermostat.Wait five minutes and allow the system to respond.Thanks.
Jan 31, 2011 | Heating & Cooling
I have a Daikin split system ducted aircon. temp on 22degrees.turns off error code flashes E5, and a picture of a spanner
E5 Outdoor activation of compressor over heatprotection or motor lock
Check condenser coil. If dust blocked-clean it.
Check out door fan motor is working. If not replace capacitor or motor.
Check compressor-gradually amps increasing-replace capacitor.
Check for gas pressure. No gas also gives over heat compressor.- Leak test and rectify.
Jan 16, 2011 | Heating & Cooling
I have a Carrier Aircon. Model 42QH12-C and it is displaying error code 5. The aircon stays on for a while (anywhere between 10-60mins) and then turns off and displays E5. If I just press the 'on/off'...
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Dec 20, 2010 | Carrier 38CKC042 Air Conditioner
LG LSC183VMA Split System Air Conditioner Logo
4,250 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
