Question about Honda Electrical Supplies
I have a Honda ES6500 generator, when it gets hot I loose governor control. I think the crankshaft gear that drives the governor is slipping on the crankshaft. Has anyone encountered this problem? email:acpower@roadrunner.com
3 Suggested Answers
spekgt
  • 60 Answers
SOURCE: My Honda ES6500 watt generator keeps blowing 15 amp fuse
Hi there .
In my opinion you should remove the starter and check the starter first . After you remove the starter get a good 12v battery and 2 wires and test the starter . Make sure to not invert polarity . After you touch the wires on the contactor (small solenoid on the side) see if the overrunnig (part with gears) comes out easy and with no obstruction . If the overrunning does not come out you could have a bad contactor (part # 31204-ZA0-003) or a bad starter (part # 31200-ZA0-701) .
Hope this help
Posted on Sep 02, 2009
GeneratorDan
  • 44 Answers
SOURCE: I need a repair manual
Try ebay thats were i go to find a hard to find manual. Hang onto that generator those es 6500 s are hard to come by . Hope this info helps
Posted on Nov 07, 2010
Unable to control over-revving on Honda gx340, is this a governor issue and how do I fix it??
most likely a governor problem
check for broken governor control spring on the arm/lever
Dec 13, 2016 | Honda Electrical Supplies
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
Model 31G777 Need to know what the timing position is for this engine please ,As stated earlier I have it at 3 o clock it wont start . ideas please
Don't waht your trying to with the 3 o'clock position but crank and cam timing marks align with each other.
Instructions from service manual:
Install Crankshaft and Camshaft
1. Lubricate the cylinder bearing/oil seal with engine oil.
2. Install intake and exhaust valve tappets.
3. Support both ends of the crankshaft, and carefully install into the cylinder.
NOTE: The counterbalance system, if equipped, must be assembled to the crankshaft before installing into the cylinder.
4. Assemble connecting rod assembly to crankshaft.
5. Install the timing gear to the crankshaft with timing mark out. The flange of the gear must face the counterweight link, if equipped.
6. Install camshaft, making sure tappets clear cam lobes. Timing marks (A, Figures 6, 7, 8) must align.
7. On horizontal crankshaft engines, make sure the paddle on the governor shaft (B, Figure 6) is rotated in line with the governor cup inside the crankcase cover.
8. On vertical crankshaft engines, assemble governor gear/oil slinger (B, Figures 7 and 8) to camshaft. Make sure the paddle on
the governor shaft is contacting the governor cup (C).
Apr 07, 2015 | Garden
Does anyone know how to clear error codes for a honda es6500 generator
Depending on generator the error code is a wrong set governor, or a GFI on the electric side of unit. Push the reset button on the GFI an that should clear it. If not you will need a dealer.
Jan 27, 2015 | Honda Cars & Trucks
How do i remove the starter on a Honda ES6500 generator
Remove ground wire from battery post. Make sure unit is off too. Remove start wire and cable from starter and both bolts. Reinstall in reverse order.
Feb 11, 2014 | Honda Electrical Supplies
I need a repair manual for a Honda ES6500 generator, can you tell me were to find it.
Nov 01, 2010 | Honda Electrical Supplies
Hi there .
Hope this help
Aug 27, 2009 | Electrical Supplies
Electrical Supplies Logo
147 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
