What is power consumption of wharfdale lpdtr 250
  • 32 Answers
It is around 17 watts and around 11 watts in Standby
Posted on May 27, 2010
What the differences of different hardware version?
TN11SCC TN16SCC TN21SCC TN22SCC TN23SCC TN51SCC TN52SCC TNK2SCC Specification Power consumption:
27W Power consumption: 32W Power consumption: 14W Power consumption: 10W Power consumption: 10W Power consumption: 18W Power consumption: 23W Power consumption: 26.7W Appearance Has shelf ID LEDs on panels - Applicable to case-shaped equipment Applicable to case-shaped equipment Applicable to case-shaped equipment Has shelf ID LEDs on panels Has shelf ID LEDs on panels Has shelf ID LEDs on panels Fuction - Provides various auxiliary interfaces and management interfaces.
Provides eight DIP switches for setting the subrack ID. Not support SCC data backup, IP over DCC, subrack cascading, and power supply backup. Not support SCC data backup, IP over DCC, subrack cascading, and power supply backup. Supports OSN 3800 V100R007 and later versions together with their feature.
Not support SCC data backup, IP over DCC, subrack cascading, and power supply backup. http://www.thunder-link.com/TN52SCC_p317.html
Sep 02, 2016 | Gateway NV5213u (LX.WDM0X.001) PC Notebook
Fuel consumption and power(kw)
Just google the make, model and year, use manufacturers specs as search.
May 18, 2016 | Isuzu Cars & Trucks
Considerable oil consumption with no visible leaks and a p301 code on my '01 e-250
p301 indicates number 1 cylinder is misfiring,that with the oil consumption, would indicate either worn valve stem guide,or worn piston rings to check you need to carry out a compression test,if compression is low the head would have to be removed to see which of the above is the culprit
Apr 04, 2014 | 2002 Mercury Sable
Toyota cressida problems
Your having a laugh here its past its sell by date
Nov 29, 2013 | Cars & Trucks
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
I want to know how many watts are needed to run a Samsung ML 1665.
you can get this information form the box of your printer.... it must be there at any side of the printer box......
Power Consumption, 250 Watts. Standby Power Consumption, 10 Watts
Jun 22, 2011 | Samsung ML1740 Laser Printer
Mustek EP A3 What power supply do I need for this?
Mustek EP A3, power supply input range is 100 Vac~250 Vac, 47~63 Hz, power consumption is 1.0 A, 15 V.
YBC (/\)
Nov 09, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
2009 KTM 250 exc-f excessive oil use, no apparent oil leaks or blue smoke
It is normal for these bikes to use some oil. A typical, maintained 250 4 stroke will use a pint of oil or more in one day of riding - depending on a lot of variables, of course. Oil consumption on these four strokes is quite typical.
Nov 08, 2009 | 2005 KTM EXC 250 Racing
I need to buy one Wharfdale Modus 8 speaker only.
Hi.
I have this modus 8 in good condition want to sell it if you wish.,
my email: devizal@cbn.net.id.
locatd at jakarta,indonesia
my mobile nos. (62) 816-809066
cheers
Apr 18, 2009 | Wharfedale Modus One-Six Speaker
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
