Question about Sharp AR-M350N Copier
What is kod e7-03on a Sharp ar-m350 - Sharp AR-M350N Copier
  • 328 Answers
Laser unit problem.20% clean mirror under copy lamp and white sheet under the glass
Posted on May 29, 2010
CODE L4-01 AR M351U
PRES: CLEAR, INTERUPT, 0, INTERUPT, 14,1, START BUTTON TO RESET THE COPIER. L4-01 MEANS A MOTOR ISN'T ROTATING PROPERLY. POSSIBLY BECAUSE OF A PAPER JAM.
Apr 15, 2014 | Sharp MX-M350 All-In-One Printer
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
Service manual manuals
http://www.smpcshop.com/Sharp-AR-M280N-Sharp-AR-M280U-Sharp-AR-M350-Sharp-AR-M450-U-N-Service-Manual.html
Nov 23, 2013 | Sharp AR-M450N Black & White Copier
I need a windows 7 driver for a Sharp AR-M350 Printer
Hi Ally, It does not appear as though there are any Windows 7 drivers for this Printer. Here is the link for the Vista drivers that you can try. Usually the Windows 7 and Vista drivers are the same.
http://www.sharp-idncservice.com/DesktopModules/SharpDriver/SDdlViewFile.aspx?IDFile=1122&file=Tiger-PS-0708a-2KXPVista.zip&location=D:\index\IdncService\AR-M350-450N\Tiger-PS-0708a-2KXPVista.zip&From=SharpUSA
If the link does not work you can go http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx and select "MFP's and Printers" select your model from the discontinued section, select Microsoft form the Driver Platform and then select Vista.
Thanks Edge.
Jun 27, 2011 | Office Equipment & Supplies
Sharp ar-m350 driver
here you can find driver for your product:
You haven't specified your operating system so I can't be more precise. For example if you are using windows xp and you want PCL6 drivers you can download them here:
http://www.sharp-idncservice.com/IDNCService//AR-M350-450N/TIGER-PCL6-V470-080-2KXP2K3-WHQL.ZIP
Just tell me wha operating system do you use and i can be more spcific.
Hope this helped you, bye
May 04, 2011 | Computers & Internet
AR-M350 H04-01 ERROR
this is a fuser error H04 01 Heat roller low temperature check the fuser (fixing unit)
Oct 12, 2010 | Sharp AR-M350N Copier
U6-03 error on sharp ar-m350... is there a code i can type in to fix it?
Tray 3 is not lifting or lowering properly. There could be a bad lift motor on the tray. The tray could have a bad sensor. Someting is either not moving the tray up and down or the sensors are not detecting the movement.
Remove the paper and the tray, inspect the tray , see if it moves freely, look for something bent or out of place.
U6-03 indicated a tray three lift problem.
Aug 09, 2010 | Sharp AR-M350U Copier
Code H4-01
The problem associated with this code is related to the fuser not heating up fast enough. H codes cannot be cleared by powering off and on the unit. A service call is required.
Feb 16, 2010 | Sharp AR-M350U Copier
Sharp AR-M350/M450 scan to desktop
Network scanner tool (or NST) comes bundled with the Sharpdesk application. It can be loaded as a standalone but it is bundled software. If you have dealer access to Sharp's website you could download the software from there.
If this is a client of yours you should be selling them another copy of the software as it is no fault of your own that they misplaced the CD plus its extra revenue.
I would love to help you otherwise, but this is copyrighted software.
Mar 23, 2009 | Sharp AR-M350U Copier
Sharp AR-M350N Copier Logo
172 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
