2004 Isuzu Rodeo Logo
Anonymous Posted on May 27, 2010
Holden rodeo brakelights dont work not even cab brake strip.
Holden rodeo ra cab chassis. my brakelights dont work not even cab brake strip.
taillights do work.
Anonymous
Level 3:
Master:
  • Master 383 Answers
  • Posted on May 27, 2010
Anonymous
Master
Level 3:
Master:
Answers
383
Questions
Helped
80905
Points
1103
Check your fuses
Testimonial: "i found problem fuses"
2006 HOLDEN RODEO RA. LOCATION of TCCM please.
Question edited for clarity.
Question moved from Spanish car company Seat, (pronounced See-At).
Check out the link
https://www.google.com/search?q=2006+HOLDEN+RODEO+RA.+LOCATION+of+TCCM
Could some one please tell me where the reverse light switch on the gearbox is on a holden rodeo ra 05 thank you
07 Rodeo Reverse light switch...where is it? - Rodeo,Colorado and ...
forum.australia4wd.com > ... > Rodeo,Colorado and DMAX Technical
Nov 5, 2011 - 7 posts - ‎4 authors
posted in Rodeo,Colorado and DMAX Technical: My reversing lights ... switch as per workshop manual..could someone throw me a bone here...thanks. ... Started By rodeo5 , Nov 05 2011 04:35 PM ... My 4WD:RA 07 Rodeo; State:NSW ... would say the reverse switch would be on the gear box some where ...
Locate & Repair 96' Pajero Reverse Light Switch - YouTube
? 1:45
https://www.youtube.com/watch?v=osie5D_m-dA
Nov 12, 2010 - Uploaded by TwoMagadan
Locate & Repair 96' Pajero Reverse Light Switch ... Replacing ABack Up Light Switch On A Manual ...
How to remove fuel tank from ra diesel rodeo ?
I may be a little off on models,, but
it should have an in tank fuel pump that cam be removed from the top of the tank, should not have to remove tank on single cabs.
does the fuel pump run for a couple of seconds after you first turn the key on, could be an electrical fault, all wires/connections/fuses in sound condition?
I have a 2005 ra crew cab 3.5L v6, it feels like the brakes are on when I select 4h. What is the cause?
Most Likely different tyre wear, or sizes, between front and rear wheels. The rodeo locks the front and rear together there is no differential between front and rear.
fuel use, wear and tear, and control are all compromised, if this is the case.
I have a 2006 holden rodeo dual cab, 3.6L v6 with tail lights playing up.. On closer inspection I cannot see any chassis earthing/grounding leads present. Is this correct on these?
Check the bulb housing and reflectors . It the housing is plastic with a metal bulb housing moulded in then there should be a black wire attached to the bulb housing. I suspect that it will be all plastic so you will have a return earth wire.
Holden Rodeo RA Workshop Manual
We are a USA site and we do not have this make in the US. Sorry.
Hi, can i program a new remote on my 05 RA rodeo without having to go to holden
If you have a working remote most locksmiths now supply and reprograme new remotes. Look them up in the phone book. If you have dont have a working remote you will have to go through holden.
5helpful
Torque settings for a holden rodeo 3.5 ra. Head
stage 1 = 29Nm(21 lb ft/3.0 kg-m)
final = 64Nm(47 lb ft/6.5kg-m)
do not reuse head bolts or apply any lubricant to the bolts. Do up bolts in following order for each head.
6 1 3 7
front
5 2 4 8
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
