Question about HP Pavilion dv6000z Notebook
I m using a ipod in which pc camera is there. i have connected it with computer. i can capture photos. now i want to use it as web cam then what to do?
    Master:
    Sergeant:
  • 383 Answers
It wasnt ment for that i would suggest a third party site but it might void your warrenty other than that call apple and see if it is possible
Posted on May 27, 2010
I have the sony DCR-HC26E handy cam i'm trying to connect it with my pc (windows 7) by using usb cable it wont work my pc doesn't recognise my camera ....thanks
USB connection will allow still photos ONLY to be capture to a computer. To capture the footage from the tape you will have to connect with a firewire cable, also called iLink or IEEE1394a. Windows Movie Maker will be one program that can capture the footage.
May 19, 2011 | Sony DCR-HC26E PAL Mini DV Camcorder
Cant not get my integrayedwebcam to work i have a averatec al in one 18.4
Important notes
The computer communicates with cameras with photo softwares required installation. Photo software installed has to be compartible with the brand camera. Generic photo softwares installed on the computer can recognise any built-in cameras, camera connection attachements. Once, a photo software has been click opened, the features fucntionalities of capturing snap shots, editing, and saving are made possible from any available camera devcies. Built-in computer cameras have already installed softwares locatable on the menu programs task bars.
A separate camera used to acquire photos elswhere requires connections to the computer from which manipulations become possible. Any already existing photo media softwares would recognise to intergrate a camera connection. For the camera to function while connected to a computer would require the feature functions of an opened photo editing program.
Note 1
A computer built-in camera can perform on the network only by opening the photo windows software provided on the web. The internet web cam for example provides the opportunity to search and locate any cameras attached to the computer for network communications. Such an instance easily recognises the built-in computer camera. A separate camera would require connection compartibilities to the computer systems, and possibly the network type. A network that provides photo camera softwares incompartible to the cameras connected to the computer would require generic softwares installations for communcations to take place between camera, computer, and a network of computers.
Notes 2
Dec 20, 2010 | Averatec D1002UHCE-1 All-In-One Intel...
How do i transfer my pics frm my laptop on my ipod touch pls advise
Transferring photos from PC to iPod touch is not that difficult. iCloud and iTunes can both be helpful.
Using "Photo Stream" to sync photos automatically with iCloud is pretty convenient. Go to "Settings > iCloud > Photos (Photo Stream on iOS 6)" and then turn on My Photo Stream. Then get your iCloud started on your PC. In the iCloud Control Panel, Check the "Photos" and then enable the "Photo Stream" option. After that, import the photos into the "Photo Stream" folder on your PC, and then you will be able to view the photos on your iPod touch. Using iCloud to transfer photos from PC to iPod touch is easy, but this method needs Wi-Fi connection. Only over Wi-Fi connection can iCloud sync photo on PC with iPod touch.
transfer-pics-frm-laptop-ipod-oxaxc0rwhkhzilrwacqreyis-3-0.png Using iTunes to sync photos with iPod touch is also easy. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPod.
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically.
2. Find "File" option on the upper left corner. Then click "Add File to Library".
3. Select photos from your PC and then iTunes will sync the photos to iPhone automatically.
http://www.leawo.org/tutorial/how-to-transfer-photos-from-pc-to-iphone.html
Jul 06, 2010 | Apple iPod touch
Web cam troubles
To simply use a web cam, no special software is required other than its driver. It becomes an input device on your computer. Many of the programs already on your computer can make use of the camera -- at least to capture still photos.
However, the ability to do tricks and other special things does require special software. It is probable that you camera came with software to do just what you describe already on its installation CD. You simply have to install it.
I hope this helps.
Aug 15, 2009 | Acer Aspire One A150-1006 Notebook
Web cam; wireless
hello there
even tho toshieba is a very realible brand and make very powerful computers it has be known to have problems with certan routers
so that could be you problem with that
now for the webcam try download arc soft camera manager
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Web Cam
It sounds like a loose connection between the camera and the computer inside the case.
The Video capture Utility says so.
And if you have no picture it comes out black.
Mar 15, 2009 | Sony VAIO PCG-K35 Notebook
Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Mar 12, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Hp pavillion dv 6700
The WEB cam (camera) is normally a USB device, it can send and capture video images as well as still images. You can talk and see people over the Internet with a WEB cam.
You need to install WEBcam software for that particular model WEBcam on your computer and configure it to run with Skype, or any other VOIP (voice over IP) software. The WEBcam software will allow you to create a video (movie) and take still photos, it will allow you to store these images on your computer.
Dec 27, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
