My washing machine keeps over flowing and the spin
It floods every where
  • 12,061 Answers
Http://www.washerhelp.co.uk/diy-repair-help.html
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above top, is a DIY self hkp troubleshooting and repair help, below is your service manual.
Posted on May 27, 2010
Samsung WF218AN washing machine is leaking from the soap dispenser
Simple sugestion, try cutting back the water in flow rate from the taps, If this works, unscrew the hose from the tap and fit a stainless washer with a small hole in the inside, on top of the wire mesh water filter on the inlet pipe to restrict the flow. Hope it helps.
Dec 01, 2011 | Washing Machines
LG 7Kg 800 Rpm the machine washing good but rinsing is not functional
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle.
Nov 20, 2010 | Washing Machines
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Washer does not rinse & spindry after getting submerged in water.
everything needs to be checked from the timer control button to the motor, im guessing it agitated through the wash cycle but wont spin now right? your flood could have damaged any number of items... run through ( with the machine unpluged ) and test the components for continuity and/or resistance.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Over flow , flood
Bottom plastic hose came off of the water level switch.
Caused no pressure to go to the water level switch.
Jan 04, 2009 | Maytag Washing Machines
I have a bosch wfk 5730 washing machine has been very reliable but now continuously keeps taking water in to machine, at timer position "F", just before the final spinning cycle begins, till it...
Could be an iffy valve/ solenoid. One test is to see the empty machine slowly fills up with water, if you leave it for a few days. You can isolate teach valve by turning each feed off in turn. i t could be leaking all through the cycle. If it is flooding during the spin I'd check your pump at well. Hope this helps.
Sep 02, 2008 | Bosch Washing Machines
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Washer Dryer flooding at spin cycle
Nicola...not sure what you mean by floods. If you mean that water is coming out of the top of the machine basket as a result of either overflow or splashing, each is different from water coming out of the drain hose.
Generally, washers which are spinning are also completing a rinse cycle...the program adds a bit of water to the spinning load to drive out the last of the detergent.
If you've got a problem in spin with flooding out of the top (basket full), this is probably a timer issue (or...less likely...a sticking water valve). If the problem is splashing, you should keep the cover closed for safety. If the drain hose is overflowing, the problem is lack of capacity to take the pumpout. Clean the drain.
May 29, 2008 | Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
