Question about Muratec Office Equipment & Supplies
Oce imagistic fx2080 copier/scan/fax/print similar to muratec mfx2030/2050 unit. i have a problem with this machine constantly calibrating itself when its time to make a copy [email protected]
SOURCE:
  • 22 Answers
SOURCE: Brother IntelliFax 4100 sending solid black pages
There are two possible solutions. Is the machine sitting on top of metal? The machine will send black pages when there is static charge. You can put a rubber mat under the machine or use a static guard. The second solution is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement. As a routine clean the scanner glass with soft lint free cloth and isopropyl alcohol also.
Posted on Oct 05, 2007
  • 7 Answers
SOURCE: Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Posted on Oct 24, 2007
  • 78 Answers
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Posted on Feb 14, 2008
SOURCE: imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Posted on Aug 06, 2008
SOURCE: muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Posted on Oct 20, 2009
I cannot get my oce fx3000 printer to print
After you install the New Drum unit you need to reset the drum counter to be able to use the Oce FX3000 again. Open the front door cover (the one you open to replace the drum or toner ctg.) On the control pabel hit the clear/back key. The display should say something like reset drum? Hit 1 for yes, close the door and you should be up and running again.
Oct 08, 2014 | Canon Genuine Oce Imagistics Fx3000...
Replacement ink
clean touch point of cartridge both side
Mar 31, 2014 | Pitney Bowes IMAGISTICS OCE IM3511,IM4511...
Splotches in prints from our SX 1480
This is actually a Muratec machine. This is not an uncommon fault and it is ALWAYS a faulty toner cartridge. Although you say you have changed it, I doubt you have replaced it with a new one.
Change it I can guarantee it will cure it. I know as I am a muratec engineer!
Jan 27, 2014 | Pitney Bowes Compatible Imagistics / OCE...
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder.
Anotherwords..you can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at www.muratec.com .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Muratec F-300 is not used for faxing, but will not copy either.
Download (FREE) the operators manual from Muratecs web site.
www.muratec.com
Make sure you are in the COPY mode(not FAX.) before trying to make a copy. As the F-300 is a "fax" machine, it will probably be in the fax mode as default.
The downloaded operators manual will help.
Mar 07, 2009 | Muratec F-300 Fax
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Jan 28, 2008 | Brother MFC-8220 Fax
229 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Ed
Ed
Adorjani Laszlo
Cosmas Matanda
Cosmas Matanda
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
