Question about HP DeskJet D1460 InkJet Printer
Buen dia, mi impresora HP DESKJET D1460 parpadea el boton de encendido
  • 71 Answers
SOURCE: hp office jet 4255 all in one ( error 0xf0af800)
Trata de bajar el nuevo driver directamente de HP e instala tu impresora otra vez. Muchas veces eso resuelve el problema
Posted on Jun 09, 2010
Rivernet1
  • 67 Answers
SOURCE: resetaear hp deskjet F2180
Pardon my rusty Spanish:
Limpa donde corre la papel con una lata de aire, en caso se quedo un pedaso adrento la imprezza.
Secundo, limpa los reduas de rubber con alachol.
Ultimo - desenchfle lo de la pade unos 5 minutos y trata otra ves.
Posted on Dec 02, 2008
SOURCE: Oxd0620230 reset power
my printer is a hp officejet j5750 all in one, the probem is that I can't scan in it, but I can print, send fax, an make copy in it, so the only problem is the scaner, plese help me
thanks.
Posted on Mar 04, 2009
SOURCE: Zebra Stripes s400
el codigo de barras sale corrido de su posicion
Posted on Sep 27, 2010
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
Como aser para recetar chip de la T430
1. entra el menu de CONFIG de la impresora. Para hacer esto:
1. enchufa de la impresora.
2. con la impresora enchufada lejos, aprieta y sujeta tanto el boton Selecto como el Regreso abotonan.
3. al mantener ambos estos botones presionaron, enchufan la impresora atras en.
4. cuando la pantalla de impresora dice que MENU de CONFIG o Principal Valor de Cnt, suelte los botones.
2. aprieta el bot?n de Menu de flecha hacia la derecha hasta que vea Repone Maint Cnt (o Repuso Maint a Conde) como una elecci?n.
3. aprieta el boton Selecto una vez. Debe ver Repone Maint Cnt en la l?nea primera y = Repuso en la segunda l?nea de la pantalla de impresora.
4. prensa Selecciona otra vez. Esto repondra al conde de mantenimiento para poner a cero.
5. salir el men? de CONFIG, aprieta el Regreso hasta que regrese en el principal menu.
6. aprieta la izquierda o boton de Menu de flecha de derecha hasta que vea la Salida Config Menu como una eleccion.
7. prensa Selecciona. Esto debe guardar que poniendo y vuelve la impresora al modo Listo. La NOTA: Si usted se pierde durante cualquiera de estos pasos, apriete el boton del Regreso para volver al principal menu. Hacer esto no cambiara ningun ajustes. Alternativamente, puede enchufar lejos la impresora por unos pocos segundos y comenzar otra vez.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Lexmark T430 Laser Printer
Buenas tardes soy de Peru tengo un problema con mi impresora HP Deskjet D2360 desde que formatearon mi PC mi computadora no reconoce a mi impresora. aparte de eso cuando quiere volver a instalarlo...
Si tiene elCD de instalcion vuelva a instalarlo con el CD o baje (recomendable) el driver en Go to HP Support & Drivers.
Para poder ayudarlo mejor vuelva e informe que SO estaba usando y que SO esta usando ahora.No esta nada relacionado con su internet
Dec 15, 2010 | HP Deskjet 2360 InkJet Printer
La impresora canon ip4600 no reconoce los cartuchos. al encernderla parpadea las luces y sale el error 6502
C?mo restablecer el c?digo de error "6502" para CANON iP4300 ip4600? tal vez los siguientes consejos pueden ayudarle:
Con la impresora desconectada, retirar el carro de tinta a la derecha, Enchufe la impresora, presione el bot?n POWER, No suelte el bot?n de encendido, y luego presione el bot?n RESUME dos veces seguidas. Suelte el bot?n POWER, pulse el bot?n REANUDAR 4 veces.
La se?al ac?stica puede sonar una vez. Luego, con la impresora desenchufada, despu?s de que restablecer la unidad electr?nica de la impresora, abra la impresora y este proceso ha terminado.
Listen Read phonetically
Dec 14, 2010 | Office Equipment & Supplies
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
En la pantalla aparece set 1 no funciona el control remoto
Presionar ENTER y el boton numerado 1 (por SET 1, 2 por SET 2, 3 por SET 3) por mas de dos segundos.
Mar 02, 2009 | Panasonic DMRES15 DVD Recorder
HP DeskJet D1460 InkJet Printer Logo
1,766 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
