Question about Nikon N70 35mm SLR Camera
Spot on images
Changed lenses and cleaned visible surfaces inside body of Canon eos350d; spot still there.
How horrible is that?
  • Obertelli
    Obertelli May 27, 2010
    Does the spot only show in the viewfinder or does it show on the photos as well?
  • austin_herno May 27, 2010
    Hallo; it doesnt show in the viewfinder or the back screen, it only shows on the images; pc or print.
    Thanks.
    Austin.
    Brigadier General:
  • 3,006 Answers
Sorry, I read this as being for a Nikon N70 35mm SLR, but now see that it's a Canon EOS 350d.
In that case, you simply have a dirty image sensor. Either use a DIY sensor cleaning kit on the sensor (put the camera body into "sensor cleaning mode" to expose the sensor), or get a professional cleaning done. Professional is best for a one off, but as the problem will re-occur then there's no substitute for the experience you'll gain by doing it yourself. Until you get good at sensor cleaning, just clone out the artefacts using your preferred image editing software.
Posted on May 27, 2010
Testimonial: "Good one, thank you."
I have a Canon EOS40D with a Canon EF 28-135mm lens. I'm getting two spots on my images - looks like dirt but I've cleaned the lens repeatedly and it doesn't help. You can see the spots on a...
The image sensor in the camera needs cleaning. You can buy cleaning kits, but often you'll just make the problem worse until you gain experience. Many camera shops now offer professional sensor cleaning so you might decide that it's better to pay someone else to do it for you. If you join a local camera club there's also usually at least one sensor cleaning guru who can do it really well if you buy him or her a beer.
Prevention is better than cure, so always blow dust off the camera and lenses before changing them, and never leave the camera for any length of time without either a lens or a body cap on the front.
Jul 14, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
I'm having an issue with a brand new Nikkor 12-24 wide angle lens. I'm getting spotting on the photographs. I've cleaned every visible glass surface to no avail. Any ideas?
What camera are you using it with?
Do you get spots with other lenses? If you do are they in the same area in all of the images.
If so you have most probably got dust on your sensor when changing lenses.
With most DSLR cameras this can be fairly easily fixed with an Arctic Butterfly brush but they are not cheap and if you are not confident about using it then I would suggest taking the camera to a repair shop.
May 31, 2011 | Nikon Cameras
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Spot that shows up in the same spot on all my pictures
It can be a piece of sticky dust or dirt on sensor surface which can't be removed with a blower or canned air. You can try to remove it by yourself with special cleaning swab and cleaning liquid. But this process requires some experience, so the safer way is to bring camera to service center where sensor can be cleaned fast and risk free.
Jul 19, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
Nikon D60 newbie : colour distortion / large smudge in photos
D-SLR cameras are designed to be used with interchangeable lenses and foreign matter may enter the camera when lenses are changed. Once inside the camera, this foreign matter may adhere to the sensor, where it may appear in photographs taken under certain conditions. To prevent foreign matter from entering the camera
  • do not change lenses in dusty environments
  • point the camera down when changing lenses.
To protect the camera when no lens is in place be sure to thread on the body cap provided with the camera, being careful to first remove all dust and other foreign matter that may be adhering to the body cap.
Remove foreign matter from low-pass filter
  1. Clean the low-pass filter covering the sensor as instructed in the camera manual or continue reading below.
  2. Have the low-pass filter cleaned by authorized Nikon Authorized Service Center
  3. The Nikon D300 and D60 has the ability to clean the sensor* using the "Clean Image Sensor" feature. Please see page 371 in your D300 User's Manual, and page160 in your D60 User's Manual for more information. *Clean Image Sensor may not remove all sensor contamination and additional manual cleaning may be necessary. See page 374 in the D300 manual, and page 162 in the D60 manual for more information.
  4. Fix images with black spots
    Photographs with dust or foreign matter on the low-pass filter can be retouched using the 'Image Dust Off' function available in Nikon Capture 4 or later (available separately) if the image was taken in the NEF format, for more information visit the article on 'How does Image Dust off' work.
Mar 24, 2009 | Nikon D60 Digital Camera
What type of zoom lenses are suitable for nikkon D-60 digital camera
For Nikon Digital SLRs there is a special line of lenses. Almost any Nikon lens will work on the D60 body, but lenses not specifically designed for a Nikon Digital SLR will lack some features offered by the body. Nikon D series lenses, that are made for the Nikon Digital SLR series, are fully compatible. Although, any lens, AI type thru D type will work.
One of the snags with Digital SLRs is that lenses designed for film cameras have different focal point characteristics, and therefore altered focal length when used on a digital camera.
A film frame is 24mm x 36mm. The CCD in a digital SLR (Charge Coupled Device, changes light energy into electrical energy, which is then recorded as a digital image file inside the camera) is not that large. So the light is focusing on a smaller area surface. This changes the focal length of the lens.
There are other undesireable effects using film camera lenses with Digital SLRs. One of the desireable qualities of old lenses is the cost. The D60 is a great camera. You lose some features with older lenses, but you still get the same image quality.
I cannot tell you exactly what zoom lens to purchase, because it's like you asking what car you should buy. There are too many variables to consider. Most pros carry the famous Nikon D 80-200mm F 2.8 ED, which is a pro lens, with big weight, superb optics, and no finicky soft spots.
It's clean all the way through the range, at every aperature. But the cost is high, probably more than you paid for the D-60 body. But if it were me, I'd spend the money.
Jan 31, 2009 | Cameras
Spots on images
spot is dust on the sensor. unfortunately, you will have to clean your sensor by yourself (it cost 30$ in a shop) There a fonction in the menu that up the mirror so you can access the sensor. very carefull. the pixel are so small that you can not see the dust but they are there!. caution, you need to put your body on a pod, have a good light to see what you make and some adapted items to clean the sensor. If not neede, avoid liquids. good luck and don't panic.
Jul 02, 2008 | Canon EOS-5D 12.8 Megapixel SLR Digital...
Canon 30D spots
It's 99% dust, especially if it appears mostly in smaller apertures (<f/8). To test it, select a small aperture (e.g. f/16) and take a photo of a blue sky. The spots will show consistently on the same location.
They're hard to clean, so chances are you just missed them. Try again, or, better still, send it for cleaning to a professional.
Dec 21, 2007 | Canon EOS 30D Body Only Digital Camera
Spots on Rebel XT image
Dust is something that will need to be addressed. Get a Visual Dust brush and learn how to use it. You can help reduce dust by 1) changing lenses with the camera body facing down and 2) turning off your camera when changing lenses.
Sep 14, 2005 | Canon Digital Rebel XT / EOS 350D Body...
Nikon N70 35mm SLR Camera Logo
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
