Question about Sony Handycam DCR-PC110 Mini DV Digital Camcorder
Charged batteries not working...ac works just fine. But when I unplug adapter, no batteries work (i had 2 and bought 2 more new ones, because I thought the batteries had died) Is there any reason that the batteries would not work (besides not being charged).
  • glennberry May 28, 2010
    Tried that...I have two chargers...plus I tried to charge batteries in camera (turn camera to "off" position and then charge light comes on. Yellow charge light blinks for a few seconds then goes off).
    Just wondering what could cause camera not to recognize charged batteries. FYI have four batteries, both charges say they are fully charged.
    Sergeant:
    Champion:
  • 338 Answers
Having too batteries rules out that problem of being flat, this sounds like a charger or plug fault so grab a new charger and see if that works.
Posted on May 27, 2010
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
No power from battery to laptop
are you installing it with correct polarity
is one of the battery terminals in the laptop damaged so that it is not making contact
May 22, 2017 | Acer Computers & Internet
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
Jul 21, 2011 | Sony DCR-HC52E Mini DV Camcorder
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Mar 12, 2011 | Advent Netbook
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
The old battery will not hold a charge when not plugged in so i bought a new battery. the battery came today in the mail and says "plugged in, not charging" and the battery light on the front is...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
Dell 2650 DC wont work
make sure the charger you purchased has the correct voltage out and amperage(in millivolts) as requested by the laptop computer, if not you risk the chance of damaging your laptop. although they fit in the power plug, it does not mean theyre compatible. The specs should be located at the bottom of the laptop or inside the battery bay.
Apr 01, 2010 | Computers & Internet
Battery icon dont show.
Make sure that the battery makes firm contact with the charging connector. I had the same problem, but after cleaning the contacts and pressing the battery towards the contacts, it started working again. It may be necessary to put a thin piece of material between the back of the battery to increase the contact pressure of the battery and the charging connector
Jul 26, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Sony Handycam DCR-PC110 Mini DV Digital Camcorder Logo
107 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
