Bad sector i have a problem whit my harddisk. Bad sector in partition magig 8.
I have problem whit my harddisk-bad sector
Posted on Apr 10, 2008
Drive not recordnized
Hi
please explain more information about your problem.
before any further assistance try to check it on other computers and see if its working or not if yes then take a full backup quickly,
if not then:
try replace the USB/SATA/PATA cable and check if it is working or not.
if not then:
1-this is an external drive:
1-1: it use as a normal external HDD for backing up data/movie/music/pics/etc.:
option number 1:try to fix its partition clusters/sectors with some software like easeus partition recovery or ...
option number 2:try to format it and then recover its data via recovery applications like easeus or "get data ntfs back" or...
note: in all scenarios you may lost some files or content
1-2 it is used for speed up your computer or has the MBR or EFI boot partition and has an OS installed on it:
try to fix its partition clusters/sectors with some softwares like easeus partition recovery or ...
2-this is an internal drive:
1-change the SATA/PATA cable
2-check its sectors or clusters via software (windows check disk or windows defragment option) for bad sectors or cluster issues
3-try to fix its partition clusters/sectors with some software like easeus partition recovery or ...
if none of my solution works or software found some bad sectors that could not resolve it then or even you couldn't format the drive then:
maybe it has a hardware fault and there is not much you can do about it by yourself and you should go for warranty service or replacement or asking some expert companies for recovering your data via some special hardware that it may cost you too much.
best regards
Jan 13, 2018 | LaCie Computers & Internet
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
COMPUTER CRASHES WITH BLUE SCREEN REINSTALL O/S BUT NO FIX. HARDWARE PROBLEM? IF SO WHICH WOULD YOU REPLACE FIRST OR IS IT M/B PROBLEM
dear hi......
its not motherboard problem .....
its RAM related problem change your system ram .......
Nov 09, 2009 | ASUS P4S800D-X Motherboard
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
My computer didn't recognize my harddis
Ok, the data may not be lost.
Need info:
- what kind of HD
- what operating system you use; windows?
- what kind of HD, is it a SATA drive?
- When you boot, (windows) do you see the drive (the faulty one) note the drive make and model number
- is this the BOOT drive or you just use it for data?
Apr 09, 2009 | Western Digital Caviar 40 GB Hard Drive
Hdd does not setup xp
You can use Partition Magic. By this software, you can repartition your HDD & Hide the partition that have BAD sector. Make a new partition without bad sector space & active it as a primary partition. That's ok. Now you can install XP.
Feb 11, 2009 | Quantum (SE21S011) 2.1 GB Hard Drive
HardDisk
Just continue in formatting the hard drive because this can be cause by some malware that's why your hard drive is just showing that size and after you format it everything will be clean, the other reason why the hard drive is just shwoing that small size even though its a big size there's a possibility of bad sector on the hard drive so don't use the quick format when you reformat the drive so the bad sector will be fix also...
Oct 14, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Hard disk problem
your hard disk is developing bad sector (it will be dead) so better to backup your data
May 17, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Samsung harddisk problem
How to Find Bad sectors and how to block bad sectors manually?
Dec 24, 2007 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Harddisk Bad sector & not detecting
Hi, If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage. Hope this be of some idea/help. Good luck and kind regards.
Sep 28, 2007 | Seagate ST3250820A 250 GB EIDE Hard Drive
Televison & Video Logo
Top Televison & Video Experts
