Question about Biostar MCP6PB M2+ Motherboard
My mobo doesnt beeps nor video output
Hi my mobo doesnt beeps , there is power on video card, cpu, sata drives, all fans on, but no video output,i tried changing rams ,reseting cmos,tried with onboard video card, tried with 2 monitors
so i think my mobo is dead..
the question: how to check if it is absolutely dead?
what can i do?
thanks
att c3z4r
  • 20 Answers
Your bis/firmware will be corupted.download latest firmware in bootable cd format and update bios.even if mb doesnot give display it can boot and flash the bios.(follow website for details on how to make cd-iso)
Posted on May 27, 2010
Video failure post beeps.. i have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one...
Hi, Thanks for using fixya.
Go into the bios stettings and check the intergrated video graphics are disabled. If you can't see the settings replace the motherboard again.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
Feb 28, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one long then two short, with...
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
Mobo will not power on if two sata drives are connected . The fans on system and cpu will not spin. System will power on and fans will spin if second hard drive is unplugged and system will post and boot...
good day sir, hi, its either your motherboard does not support 2 sata drives simultaneously or your motherboard sata port is bugged.
Choices:
1. get a bigger hard drive
2. use a PCI to SATA card for your extra SATA hard drive.
3. replace your motherboard.
Hope this may help.
Dec 17, 2009 | ASUS Computers & Internet
Motherboar fail, no video, power supply ok help
Firstly, remove the RAM and turn on the system, if you hear the beep sound continuously that means everything is perfect expect RAM.
Clean the track of RAM at both sides by pencil eraser completely.
Also clean the port of RAM.
Secondly reinstall the CPU with CPU FAN and also clean the FAN.
Third one is that remove all the add-on's card and than turn on the system.
Apr 12, 2009 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Recently built a PC Power is On with No Display
Well depending on your bios version, it could be an array of things.
First try removing the video card and re-seating it.
Then re-seat the RAM.
If the problem persists re-seat the CPU.
Let us know the exact model of your motherboard so we can better troubleshoot your problem.
When you turn on your computer the system does a POST (Power On Self Test). If the POST sees an eror it will tell the BIOS (Basic Input Output System) and the BIOS will beep a code or display a code that indicated the problem.
Different motherboards contain different BIOS versions. BIOSes use different beep codes for problems depending on the manufacturer.
Mar 24, 2009 | Abit IN9 32X-MAX Motherboard
No post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
Mar 19, 2009 | MSI P4M900M-L Motherboard
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Computer gets power, but doesn't display anything
remove your video card and plug it again.. if it doesnt work..
try plugging ur video card to *********** board built in video card and then ur on-board video card to you monitor..
this is what the nvidia guys mentioned on their video while announcing the release of the 9 series
May 07, 2008 | Toshiba Satellite P25-S607 Notebook
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Biostar MCP6PB M2+ Motherboard Logo
282 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
