Question about Kodak EASYSHARE 5100 All-In-One Printer
Slow printing specs say up to 32 ppm takes me 72 sec to print one text page with about 30% coverage
    Problem Solver:
  • 14 Answers
Not really, it depends on the quality of picture you are printing..
also check the cable that you're using, longer you have, the slower the data will pass into it.. and the speed of you're pc, actually both are the factors on this one..
Posted on Apr 14, 2008
SOURCE:
I'm using half of A4 size paper and when I print my file on it, it takes 20 seconds after feeding the paper. Is there anything I can do to make it faster?
I fixed your capitalisation, punctuation and grammar. Half of an A4 sheet is an A5 sheet and should take half as long to print an A4 sheet. Print speed is dependent on a number of variables;
Density of colour, the more colour or more blocks of black take longer. Yours is monochrome and these are the specs. You should get 12 pages per minute. It may be that your computer is slow and also is low on available RAM memory. This is an old printer and you may think about upgrading. I had one of these 10 years ago.
Benefits
  • 12 ppm mono printing
  • Zero warm-up time from sleep mode
  • First Print Out Time in only 9.3 seconds
  • Up to 2400 x 600dpi print resolution
  • Energy efficient and quiet operation
  • Easy to use All-in-One cartridge
You should get 12 pages per minutes
Sep 16, 2015 | Canon LASER SHOT LBP-2900 Printer
Unabel to print 72
This is a hardware issue, you may need to bring this into an authorised Brother service center for repair
Mar 25, 2015 | Brother DCP-7055W Laser Multifunction...
Printing error message The printhead appears to be missing, not detected, incorrectly installed or incompatible.
Here is how I would approach this.
1. Open the cover and look at the print head. Are the cartridges installed properly and locked into place? You may wish to re-install them to make sure.
2.Inspect the print head to see if any cables appear to be pulled away or damaged.
3. Unplug the printer, and let it sit for about 30 seconds, and then apply power and turn it on. Let it run through it's initialization and then see if it provides any error codes. You may also wish to try printing a test page to generate an error code.
Good Luck,
Feb 10, 2015 | HP CB863AB1H Officejet 6100 H611A Inkjet...
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
Why is my printer printing in code
Remove your current PDF driver and then install the latest PDF driver for your model and operating system
Aug 14, 2014 | Epson Expression XP- 605 Inkjet...
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Too much ink to few padges printed
The 1000-1500 mark is usually just a guess - it usually assumes no more than 15% coverage of the page.  If you are printing out very large pictures (full page images) or are printing lots of a single color (green landscape images), then the ink will run out a LOT sooner.
May 27, 2009 | Office Equipment & Supplies
C6180 printing slow
This could be from the image you are printing. If you are printing from a computer or memory card, the dpi (dots per inch) may be higher than some.Standard printing is typically 400dpi, and you can change the settings on your computer or the printer directly. Memory cards and some photos from your computer may be 600dpi and will likely take much longer to print since there is more "color information" that it is trying to fill.
Let me know if this helps.
Jan 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP PSC1350 All-In-One Printer
This printer prints at a really slow 1.4 PPM, and if it's doing that, it means that the buffer in the printer is full and it must print what it has in memory before recieving more of the page, if it's a really high resolution picture, it can take forever to print. This isn't a defect at all, it's just something that you can't fix that makes this printer useless for an office. I have this printer too, I usually just go do something while it does its thing...
Aug 14, 2007 | HP PSC 1350 All-In-One Thermal Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
47 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
