Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
NO taskbar + no sound
I opened my computer I was shocked because there is no taskbar I tried pressing window key start menu doesnt open I tried regedit gpedit.msc and tried to find some edited setting but unluckily I found nothing...I need an urgent response because I couldnt access my startmenu to adjust my volume control.. Advance thx to someone who could really help
  • 128 Answers
Press CTRL+ESC. If your Taskbar magically reappears, then it's probably simply been resized too small, repositioned somewhere you didn't expect it, or perhaps it's beneath another application that's running full-screen on your computer.
If CTRL+ESC didn't make it come back, then the program that displays the task bar most likely isn't running. That program is often called the "Windows Shell", but it's really "explorer.exe". It's the program that not only displays the Taskbar, but also responds to the CTRL+ESC sequence.
The workaround: press CTRL+ALT+DEL to fire up the Task Manager. Now on the File menu, select New Task (Run...). Type in "explorer" and press OK. That should restart explorer and re-display your Taskbar.
In some cases that may not work, so we fall into the various approaches on fixing it.
If you don't have the Windows Shell running, you can still run programs as I described above: use Task Manager's File, New Task (Run...) to run the programs we need. I often like to run a command prompt, "cmd", as a quicker way to type in and run other programs from there.
My first recommendation is to run an up-to-date anti-virus and anti-spyware scan. Both viruses and spyware are known to occasionally interfere with the Windows Shell.
Then, I would run the system file checker, That will check for missing or damaged files in Windows, and repair or replace those that it can.
OR
Please visit the link for more explanation on this solution. (http://support.microsoft.com/?kbid=318027)
Posted on Jun 03, 2010
  • 108 Answers
Press Ctrl+Alt+Del when it stops at Blank Desktop.. Go to "New Task", Type "Explorer" at "Run".. if the problem occurs, you may have to repair your windows... follow this step...
Take your WINXP Bootable Installation Disk, Boot it, Repair your system (First Repair Option) using repair option.. Thats all.. Your previous settings will not be disturbed.
Posted on May 28, 2010
How to get taskbar back
Hi, if your on a Windows system press the Windows key to open the Start menu, in the Search option at the bottom type taskbar, this should show you Taskbar and Start Menu option.
Select the Taskbar and Start Menu option
Check the AutoHide option is not ticked, and check the taskbar location is set to Bottom, if you make any changes click the Apply then ok.
Aug 28, 2014 | Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
Sound icon doesn't show up on bottom toolbar
Right click on any blank part of your taskbar, then left click on Properties, a windows titled "Taskbar and Start Menu Properties" will open : click on the "Notification Area" tab, then, under Syatem Icons, put a check mark on "Volume", then click on "Apply", click on "OK" and the "Taskbar and Start Menu Properties" window will close and you will have the Volume (Sound) icon in the Notification Area of the Taskbar.
Sep 19, 2010 | Computers & Internet
Missing task bar - running vista
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
Jun 02, 2010 | Microsoft Windows Vista Home Premium...
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
I cannot see my desktop icon taskbar and start menu. though i opened it by pressing ctrl+alt+del and going to task manager and running explorer. but when i shutdown or restart my computer i use to go...
Press CTRL+ESC
If your taskbar reappears, then it was just accidentaly been resized and repositioned somewhere
IF that doesnt work :
press CTRL+ALT+DEL to run task manager. On the File menu, select New Task (Run). Type in "explorer" and press OK.
Feb 18, 2009 | ASUS A9RP Notebook
Missing taskbar and start menu
Probably your infected. to fix the problem u can visit kelly's korner and copy all the text and then go to notepad and paste the text and then save it as "taskbar.reg" and then after saving it run it. it will prompt you if u want to add the registry information and you say yes. see if that fix's the problem. if u dont know how to open notepad without the startmenu u can try pressing windows key+r and type "notepad" and press ok. remember to save it as a .reg file.
Nov 26, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
