Kenmore Washer - error code f32
Kenmore elite washer He3t shows error code f32. Fills, motor runs, no further action. The book doesn't show an f32 code.
  • 3 more comments
  • Nixonian May 02, 2008
    Exact same problem experienced with our Kenmore Elite Front-Load.
  • Anonymous May 21, 2008
    turn off power
  • tiggerwoods May 31, 2008
    We just got this washer. We've attempted to turn it on for the time and we have come up against same problem mentioned here.
  • Anonymous Apr 23, 2009
    I just bought some and I'm very unsatisfied half way through the wash cycle it pops up a error code F32 not one load washed
  • mrckee Apr 23, 2009
    I just bought some and I'm very unsatisfied half way through the wash cycle it pops up a error code F32 not one load washed KENMORE ELITE HE4T IS ****
SOURCE: Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Posted on Oct 02, 2008
jyackle5
  • 8197 Answers
SOURCE: there is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: kenmore elite HE3t
Unplug your machine, remove the top panel, doublecheck all of the wires are securely connected. Sometimes the wires are loosened due to the vibration of the washer. Hope this works for you! It worked for our Kenmore Elite H3 when no cycles would start and flashed the error code "dL/F" (door lock failure).
Posted on Jan 02, 2008
reg501
  • 413 Answers
SOURCE: kenmore elite HE 3t washer
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Posted on Jul 04, 2008
jsrock516
  • 5911 Answers
SOURCE: My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Posted on Sep 14, 2009
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
There is an error code comming up it is f32
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3t washer
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
582 people viewed this question
Top Washing Machines Experts
