CAN NOT PRINT A DOCUMENT. - Computers & Internet
Well, that's certainly a descriptive problem.
Solution:
If you still have the original packaging for the entire computer system, pack it all up, being sure to include all CD's, cables, manuals, etc.
Take it back to the store you had purchased it at.
When they ask why you're bringing it back, or inquire about any defects, simply tell the customer service person that you're too stupid to own / operate a computer, and they will be glad to issue you a refund, and will appreciate your honesty.
Posted on Apr 07, 2008
SOURCE:
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type Normal.dot or Normal.dotm depending on your version of Word.
  4. For each occurrence of the Normal.dot or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template (Normal.dot). However, existing documents that were created by means of your old Normal.dot file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
My Printer not print given blank pages
You'll need to reboot your computer. You'll also need to turn off your printer (on/off switch or unplug the power cable).
Then plug everything back in and bring your computer back up. Most of the time this will solve the problem.
If the printer won't print just one Word document, then the document got corrupted just a tiny bit. Rebooting the computer won't solve that problem. However, if you can get Word to say that it 'has a problem and needs to close' (while the bad document is open), then it will recover and repair the document. Reopen Word, and you will see a list of recovered documents. Click on your problem document and open it. The recovered document should be able to print. Save that recovered document as a copy of the original one and print it.
I've had both problems, and these solutions worked for me.
Brother Printer Support
Sep 14, 2012 | Brother Ink for Dcp145c Lc-980
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Every so often when I try to print a document I
Try reinstalling the printer driver, make sure you uninstall it first.
Jan 10, 2010 | HP OfficeJet G55 All-In-One InkJet Printer
How can i print my faxes that are received in memory? My fax is flashing - Auto Print Off - Rec'd in Memory. How can i access my faxes from there?
Here are the instructions from the onscreen manual from Canon USA.:
Printing or Deleting a Document in Memory
1 Press the FAX button, then press the Menu button.
2 Press the l_mark.jpg or r_mark.jpg button to select MEMORY REFERENCE.
3 Press the OK button.
4 Press the l_mark.jpg or r_mark.jpg button to select PRINT DOCUMENT or DELETE DOCUMENT.
bullet_s.gif If you select PRINT DOCUMENT: (1) Press the OK button.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number by pressing the Numeric buttons.
If you are unsure of the transaction number, print the memory list. See Printing a List of Documents in Memory.
(3) Press the OK button.
(4) Press the l_mark_s.jpg button to select YES to print the first page only, or press the r_mark_s.jpg button to select NO to print all pages of the document.
(5) Press the OK button.
I hope this answers your question.
Dec 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Open Questions:
Medialink router customer care number%%[+l^33O{233O}}%%:~NumbER USA Wngots Medialink router WngLogin customer care Number +[184433O{233O}]WngLogin Medialink router tech support number USA Repair service center to resolve all Medialink router tEcH SupPoRt pHoNe nUmBeR products. Medialink router is an American multinational company which was founded by Michael Medialink router using its company headquarters in Round Rock, United States of America. Contact Medialink router for Setup & Installation Medialink router Setup Free & Installation Medialink router TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Medialink router Connect, Medialink router TECH Free Phone Number you'll be searching out Medialink router Connect setup as well. So, here we're with all cthe setup process and for your to Medialink router Connect. Get Medialink router Setup Instant Free Medialink router TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Medialink router Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 19, 2019 | Carrier Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
