Question about EA - Electronic Arts Need for Speed : Most Wanted
I cant go inside car shop ,safe house or car repair during free roam..??? wat shall i do..???
Go the controls, give the Engage event Enter and then try again.
Posted on Jun 08, 2010
I cant connect to ea servers and stop working in LAN whats problem???????? BLACK
Posted on Feb 06, 2013
Yes,its right..this solves it dude..chandukb..dude you rock..I reached till Blacklist 3..was winning everything but without customising and upgrading it was no fun...thanks a ton
Posted on Jun 27, 2010
Asus k53E sx 194 ov start up wont repair cant do nothink useing my sons dell
Julie, start your laptop and before it gives the start up windows logo, press F8 a few times. If you pressed it at the right time than you shall see a bunch of options:
First, try to boot your computer using "LAST KNOWN GOOD CONFIGURATION" and see if it works. If it works than its all fine and smooth sailing. Login to your windows and then as a precautionary measure, Re-install your Windows from the Asus Recovery Manager.
Second, if the first option fails, then select, "SAFE MODE" option and it shall login windows Safe Mode. From there go to Asus Recovery Manager and re-install your windows to be certain that it shall work fine now.
Nov 01, 2012 | Computers & Internet
T foreward or rewind. kicks out the tape.
You ether got a bad mechanism, something inside Kids like to stick coins/ Grilled cheese sandwich's in the mechanism instead of tapes or you had a band break.
I would say have it looked at by a VCR repair shop or have a look inside yourself for any objects that might be out of norm.
You will never believe what you find in these units specially if you got kids roaming the home.
Please do not forget to rate and leave feedback for your free answer today.
Thanks
Oct 21, 2010 | Sylvania 2870LV VHS VCR
On my 02 windstar the half axle has play where it goes into the trans... changed axle and it was fine some bearing is worn inside and i cannot find the replacement part or how to repaire my problem. any...
from what you discribe the housing bearing is on its wat out,and needs replaced and not an easy job ,if you cant find the part try ebay.But i would find it hard to believe that you could not get the part from a auto shop its not a costly part.adrian,,,,
Aug 18, 2010 | Ford Windstar Cars & Trucks
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Fault
the only thing you can do yourself is leave the set unplugged for over an hour, this will reset it to factory settings. If that does not do the trick it will need to serviced. Chances are if it is a rear projection set that the convergance board is dead. This would be more to fix than the tv is worth.
Jul 07, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Cant enter the repair shop
You're not supposed to do anything but drive around in free roam mode to learn where everything is at. If the problem persists and goes into the career mode then I would have your disc resurfaced. That might also fix any problems you are unaware of.
Jun 08, 2009 | EA - Electronic Arts Need for Speed : Most...
Laptop won't start up in Windows due to a missing or corrupt file
No all you have to do is follow its instructions and use the Windows XP cd and during startup boot to the cd and during installation choose the repair option.
This will not make you lose any files and then you will be able to get in and back to work or whatever it is for again.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Please help
Your phone needs to be reprogrammed, only a repair shop can do this for you.
-_-_-_-_-_-_-
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 01, 2008 | Nokia N73 Cellular Phone
I have a sony errison 850i mobile fone and wanted to know can i block certain numbers from ringing me
sory your language i cant folw it.
kindly as US ENGLISH. PLEASE
Good luck and kind regards. Thank you for using FixYa.V
Feb 22, 2008 | Sony Part 996804671 Service Manual for...
Compaq presario v6000 network problem
Check to see it hasn't become "Disabled" in Device Manager. if is is, Enable it again. If necessary Uninstall & Reinstall the "Driver". Try Booting in Safe Mode with network support... & see if it's OK or not... If it IS OK in Safe Mode, that means that you have a "Driver" conflict to be resolved. I wonder here if the "Repair Shop" hasn't got some responsibility,indeed it may be something they have done.. or maybe neglected to do.. during the latest "Repair". I would go back to the shop and politely indicate that it has gone faulty & *never* really worked... (a little white lie) since you got it back.. and it was working 100% A OK B4 they "Fixed" it... & could they please have a look at it for FREE.. If you were MY Client I would have NO problem with that.
Sep 03, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
EA - Electronic Arts Need for Speed : Most Wanted Logo
1,076 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
