Question about Sharp R-930AK Convection/Microwave Oven
Will not turn on. Has power to fuse, but does not turn on anything.Model is Sharp R-930AK-F.
  • Sharp Master
  • 9,098 Answers
We have the service manual for this model and have uploaded it for you here.
You can order parts for this brand from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 28, 2010
Testimonial: "Very helpful, will use again.....Thanks,"
Magnetron part for a sharp carousel Microwave oven Model R-930ak
Maybe a faulty magnetron but check for abnormal noise caused by faulty diode pack. If you are in UK google the part number
RV-MZA114WRE0
R930AK Sharp Sharp Microwave
Apr 07, 2017 | Sharp Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
"Sharp R-930AK Service Manual"
The service manual is here.
You can order parts from Encompass here.
Aug 26, 2011 | Sharp R-930AK Convection/Microwave Oven
Why did my sharp microwave lose all power
remove cover and check small fuse, if fuse is bad it ussually is caused by a failed door switch, hope this helps
Jan 31, 2010 | Sharp R-930AK Convection/Microwave Oven
Sharp carousel model number R-930ak + parts The plate inside does not spin sounds like a cheap plastic gear on the bottom is worn out and stripped. MAkes a clicking sound
This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
For the model number you have listed, the part number is 46-841666-3.
You can purchase replacement parts at searspartsdirect.com.
The site also offers helpful exploded view diagrams to assist you in parts location/identification. The motor is listed at item 001-20 under the "Cabinet" heading. If you have any questions, please post back and let me know. I hope this helps you.
NOTE: You also consider the turn table coupling, which is item 004-22. The underside of the coupling has a keyed slot that fits on to the turn table motor shaft. If the coupling becomes cracked, or if the keyed slot "rounds out", it may be slipping on the motor shaft and not turning.
Dec 17, 2009 | Sharp R-930AK Convection/Microwave Oven
I have a Sharp R930 which was OK last night. This morning there is no power on the unit, the wall outlet power is OK.
(Our site is down as I write this, but rest assured it is there.)
Check the fuse, the magnetron's temperature fuse, and the oven cavity thermal cutout on top of the cavity.
You can order parts from Encompass here or call them toll-free at 866-779-5835.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 26, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Sharp R-930AK convection/microwave suddenly died
You need to open the oven (unplugged) by removing the screws along the case. Inside, there is a 20 amp fast blow fuse that you can get at Radio Shack. It looks cylindrical and white. I would test that first. However, replacing the fuse may work, but then, other components may have shorted inside causing the fuse to blow. Try the fuse replacement/test it first. Good luck
Apr 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Blown fuse
These items are not expensive
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757868&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757867&PPStack=1
Insert your model ( sharp R930AK ) at search tab of link below and select "thermostat/Thermal fuse " at PART TYPE to see parts availability
Jul 05, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
550 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
