Question about JVC KD-G120 CD Player
Have power--cd insertsand ejects but no sound on switch does nothing-source does nothing disp lites up time for few seconds only can you help
    Scholar:
  • 111 Answers
You should go back and check your wiring. It sounds like your memory and constant power wires are crossed. While back there, check ground to make sure it's good as well.
Posted on May 27, 2010
Faceplate has not illumination
I'm not sure what you mean by extra red wire. Are you saying that there are two red wires? Generally most radios these days require two power sources. The yellow wire for most after market goes to a constant power source and the red wire goes to ignition or switched power source. Both wires need to be hot in order for the radio to work.
Mar 03, 2013 | Metra Ibr-whgm2 Wiring Harness For Most...
Hi, my JVC KD-R311 will not turn on, if I press eject the unit lights up and makes an eject sound and then goes blank or if I press the top right disp button, the display lights up for a few seconds. I...
you need to connect the red wire coming from that is not being used in the plug to the cd player then feed it through to you cigarette lighter. to find the live wire just rest the copper onto the metal and then once found it unplug the cigarette lighter there should be a ring feed the copper wire through, reattach plug it back in and you should be all set up!
May 14, 2011 | JVC AM FM CD DET FACE CAR STEREO
My kdcmp443 seems like it resets every time i turn on the car. and it starts with demo mode, regardless of if i turn it off or not previously..... thanks
Did you do the install yourself? If so, it sounds like you need to connect the yellow wire to a constant power source. That is, a source that is still hot with the key turned off. The yellow wire provides power to the memory of the radio.
May 04, 2011 | Kenwood KDC-MP342U Car CD Player
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
I have a jvc kd-s590 in my car & have no idea how to set the clock. It'd driving me crazy. Please help!
1 Press and hold SEL (Select) for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Set the hour. 1 Select "CLOCK H" if not shown on the display. 2 Adjust the hour. 3 Set the minute. 1 Select "CLOCK M." 2 Adjust the minute. 4 Press SEL (select) to finish the setting. 1 2 During tuner operation: During CD operation: Frequency Clock To check the current clock time (changing the display mode) Press DISP repeatedly. Each time you press the button, the display mode changes as follows. To Cancel Advanced SCM You can cancel the Advanced SCM (Sound Control Memory), and unlink the sound modes and the playback sources. When shipped from the factory, a different sound mode can be stored in memory for each source so that you can change the sound modes simply by changing the sources. LINK ON: Advanced SCM (different SCM for different sources) LINK OFF: Conventional SCM (one SCM for all sources) 1 Press and hold SEL for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Select "SCM LINK" if not shown on the display. 3 Select the desire mode - "LINK ON" or "LINK OFF". 4 Press SEL (select) to finish the setting. • If the unit is not in use when you press DISP, the power turns on, the clock time is shown for 5 seconds, then the power turns off. 1 2
Nov 03, 2010 | JVC KD-S590 CD Player
We installed a jvc kd-s26 into my 2002 trailblazer, I believe correctly but the radio will only turn on for about 15 seconds and then powers off.... I do not understand
There are two power wires for the receiver. One will light the clock and eject the CD when the eject button is pressed, but will only stay on a few seconds and this is connected to a battery source. The other power wire actually turns on the radio and is connected to a source controlled by the igition switch Check the wiring diagram to see if you have both wires connected correctly.
Feb 02, 2010 | JVC Car Audio & Video
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
Player shows ejects symbol and shuts off after about 45 seconds
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
Jun 13, 2008 | Sony SLV-D251P DVD/CD Player w/Built-in...
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
JVC KD-G120 CD Player Logo
69 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
