Question about Canon imageRUNNER 1023iF Black and White Copier
Uneven copy quality- Canon Copier
Hi
I am using a CANON IR 1022 copying machine and lately have started getting uneven image and print quality. There are some smudges and wipe offs on images and text. I tried to change the charge roller but didnt help. Any clue what may be wrong?
Regards
Rahul
  • 41 Answers
If the fixing film is broken text and images will not fix properly. so check fixing film and pressure roller and replace the new ones.
Posted on Jul 29, 2014
  • 1,219 Answers
If the toner isnt burned on paper it means that you have to change fixing roller bushings and fixing roller.
Because you have uneven pressure between fixing and press roller
Posted on Jun 02, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Sir i hav a doubt in canon ir 3300.
Hi. have you tried to adjust density in the user mode?
May 01, 2017 | Canon Ir 3300 B/w Copier image Runner...
What are the steps to solve light copies with canon ir 1024 copier
Did you clean the optik lens,mirrors...?It may also be a transfer roller,try to clean or replace it.
Sep 03, 2014 | Canon IR-1022 Copier
Some of the letters in printed copy come out uneven
This problem may be caused by several reasons. Bad nozzle pattern,dirty film encoder,etc. Sometimes,perform printhead alignment may solve the problem or else you can set print or copy quality to HIGH.
Simply try to align the printhead or/and set print or copy quality to HIGH.
Recommended source:
Printer Clinic
Dec 12, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon mf 6540 copies come out uneven
Did you clean beneath copy glass ( adf copy glass and platen )?Did you clean scaner also?
Clean the laser unit.
Not genuine toner isnt best solution.
Try to print something.If the print is OK, then the problem is in copy glass and scaner.
Jul 02, 2010 | Canon ImageClass MF6540 Copier
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
I have problem in ricoh 1022 image repeat problem i cheek fusing drum and replace its still same befor fusing copy ok when enter in fusin then its give the problem what i should do tell me
The problem is that the Upper fixing roller needs to be replaced... Most likely the coating on the roller has worn off and the bear metal is exposed and the toner stick to the metal and reprint it futher dow the page.... It could also be uneven pressure with the upper and lower fixing rollers... It may be a broken bushing or ball bearing... Good Luck
May 03, 2009 | Ricoh Aficio 450 Copier
Canon ir 400 copier
Check the scanner. If the lube has dried up it could be causing the scanner to vibrate slightly when reading the image.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 1023iF Black and White Copier Logo
263 people viewed this question
old marine
old marine
