Question about StarTech.com StarView SV211K 2-port KVM Switch
BoxT problem. I HAVE PICTURE BUT NO SOUND ON ALL THE IRISH CHANNELS AND CHANNEL 4. Does anyone know how to get the sound back.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • StarTech.com Expert
  • 191 Answers
Do not delete all channels only delete the ones that have the sound gone you then have no need to turn emu on/or/ off
Posted on May 30, 2010
What caused no sound on ABC channels 2 and 21 only?
You would need to ask the broadcaster of the stations that question.
Mar 24, 2017 | Televison & Video
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Jun 24, 2009 | iLO 2600 Television
No sound on some channels, some channels have wrong sound for pic
The SAP feature has been turned on. Look for a button that says SAP or go thru the audio menu and turn it off.
Apr 09, 2009 | Televison & Video
Codes for the box t
GO TO MENU
HIT 1570
MAKE SURE EMU IS ON
NAVIGATION
CHOOSE CHORUS OPTION
5E01 (STORE)
00:
CE 19 2E 87 61 74 90
STORE
01:
62 FA D9 F3 CE 05 FA 79
STORE
EXIT
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
JVC TV
you should have a button on your remote for sound system may be 'BG' or 'SYS' or any other press it to change sound system to "BG". sound will be ok.
Nov 01, 2008 | JVC AV32F476 32" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
105 people viewed this question
Top StarTech.com Computers & Internet Experts
loftys0504
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
